2017 vs 2018 XPT and Dynamix differences noticed so far
26K views 19 replies 14 participants last post by  Dert
The 2018 part diagrams are out as of this morning.
Browse
Most of the diagrams are the same, but there are some part # variations.
2018 XPT wheel bearing is part # 3514924.
2017 XPT wheel bearing is part # 3514822.
The dimensions listed are the same, but the hub part #'s changed, as did the axle part #'s, outer CV part #'s, and axle washer part #'s. Knuckles, brake rotors, and axle nuts are the same part #'s. I have a 2018 wheel bearing on order to test fit in a 2016.
As expected, the 2018 has new part #'s for the prop shaft and carrier bearing.
The 2018 XPT has a new ball joint part # across the board, which is the second time it has been changed since 2014. The 2018 ball joint is part # 7082275, and the 2015-2017 ball joint is part # 7081992.
The front lower arms use the same base part # with only the variations for color, but the front upper arms use a new base part # which usually indicates a change. Bushings are the same between 2017 and 2018.
Clutches, frames, turbocharger, brake systems and cooling systems are the same between 2017 and 2018. As are the front diffs, fuel tanks, fuel pumps, sway bars, most of the plastics(except for color variations). Engine and transmission appear to be identical.
In addition to the new shocks, the Dynamix model gets a unique power steering motor, plus a new module and bracket that mount under the dash, and a temp sensor for the voltage regulator. Plus an assortment of other changes like the instrument cluster, and a third switch on the dash.
Stators are the same between all 2017 and 2018 XPT's, but the voltage regulators are different on the Dynamix. 2017 XPT and standard 2018 XPT gets a 50 amp regulator, but the Dynamix only gets a 35 amp regulator.
2017 and base 2018: 4014856 REGULATOR-3PH,50A,SERIES,HISPD
2018 Dynamix: 4012941 REGULATOR-3PH,35A,SERIES,105C
Dynamix also gets an entirely different wiring harness and fusebox setup. Headlights are different as well, but tail lights are the same.
Anyone see any other big changes?
Good catch, they have two new part #'s based on date of production.
Engine long block part # changed again as well:
2016 XPT: 2206213 ENGINE, LONG BLOCK
2017 XPT: 2206528 ENGINE, LONG BLOCK
2018 XPT: 2207370 ENGINE, LONG BLOCK
Headgasket part #'s:
2016 XPT: 5813737 GASKET, CYLINDER, HEAD
2017 XPT: 5814437 GASKET, CYLINDER, HEAD
2018 XPT: 5814501 GASKET- CYL HEAD, 4 LAYER [To 6/5/17]
5814693 GASKET-CYL HEAD 4-LAYER [FROM 6/5/17]
I can't find any other differences on the internals of the 2018 engine though. Same cams, head, block, pistons, rods, crank, bearings, etc as the 2017.
I am wondering if the 2018 headgasket is a little thicker, resulting in a slight compression drop, which while having a minimal effect on total power output, would help with cylinder temps. Or it could be as simple as a supplier change. No way to know until you can compare all the different versions side by side.
The starter & rotor look like they will fit (stator cover & crankshaft are same part#). Wondering if the plug is going to be the same on that end. Yes the 18 has dual 35A regulators but curious to see if the larger stator will work & use the Hawk 50a regulator on the 16/17"s
#15 ·
Interesting, they are continually updating the parts catalog.
Now it shows the Dynamix has a different stator and flywheel, when the other day it did not.
2016-2018 XPT:
4015340 STATOR
4015496 FLYWHEEL
2018 Dynamix:
4017285 STATOR-900W DUAL [BK]
4017135 FLYWHEEL-900W [BK]
Other parts are the same in that system, as of now.
There are two regulators as you speculated. They are no longer in the rear driver side portion by the trailing arm, but up front tucked right behind the front grille under the ride command GPS module. This and the addition to the fuse box being to the left of the steering wheel under the dash are the main changes in the electrical system I have noticed. The Dynamix module is under the dash and has it's own new mounting plate and plug. This is a pain to work around when installing a radio or intercom system.
