2017 rzr xp 1000 engine noise
1.4K views 28 replies 5 participants last post by  Lopaka55
Hey guys, got some engine noise on my 17 xp 1000 does it sound like it’s bottom end you to all or maybe something timing chain? Just wanting a second opinion thanks for any info.
Can’t figure out how to add a video so I side a YouTube short link thanks
That is 100% the timing chain, not a doubt about it, the sound is too distinctive to be anything else and I knew it within the first sec of your video and your in the correct location of the engine too.
I have the TRP tensioner as well, it needs to be re-adjust every few hundred miles, while the engine is warm and running. Did this sound start just after installing, or adjusting, etc? hand tighten it all the way, does the sound go away?
Reset your marks on the crank and pull the tensioner out, make sure its not broke, if turning the knob isnt making a difference this is likely the issue. If the tensioner looks good, put it back in and I would pull the valve cover and turn the crank by hand to check the chain.
  • Like
Reactions: MNichols
Auto tensioners can and do fail regularly, when they do it happens while youre out riding you are pretty much screwed until you replace it. Also a failure can result in a lot of damage. A manual tensioner in theory shouldnt fail, or atleast the likelihood of it happening is right there with: this would be the first time I ever heard of it happening. Its more so for peace of mind, there is no performance benefit to it and in the end is actually more work.
#15 ·
I might be confused. When I say auto, I mean the OEM tensioner. Are you referring to an afetrmarket auto tensioner, like the Tusk, that replaces the hydraulic OEM, I've never heard of those failing either. The OEMs however do regularly fail.
I can't say I trust the auto-tensioners either. My original one failed (granted it was 7 years and ~2k miles), had it replaced at the dealer bc I was in a pinch needed it fixed before a trip, failed again on that very next ride, and was replaced again. Have about 200 miles on this one and it seems fine for now. May have been an issue with how it was installed though, who knows.
#21 ·
Yeah quite weird, I went a head got new gears too just in case so hopefully I don’t have to worry about it. Has about 4400 miles on it. I just got it about a month ago upgraded from a rzr 800 it was a lot easier to work on. When I got it the intake valves had zero lash on them so it was making some noise, I adjusted them and still heard some noise and was thinking chain after that. Maybe the zero lash had something to do with it?
