I have a 2016 RZR 170 that is hard to start, does not idle good, and sputters very bad when trying to ride. The idle will be ok then it will start sputtering and any time it cuts out or sputters the red light by ignition flashes with every sputter, I can imagine this is an electrical issue, I have installed a new fuel pump, injector is clean I un hooked the brake sensor and soldered the wires together just to not have the need to hold brake down while starting. Its crazy that the sputtering and cutting out is synced perfectly with the red light on dash, it has new fuel, has been sitting up about 6 months, i unhooked the connections i could get to cleaned with electrical cleaner and put electric grease in all connections. any help would be appreciated.
