i have been nice to long. 1st thing was the rubber boot that covers the front cv joint. It was never crimped. 2nd the decals are just falling off.... Flapping in the wind. Now the topper... We just got done in the trails and was heading back to the trailer. When the steering column just snapped off. There is a bracket that holds the column in place after looking at the weld it was just tack welded. It was never completely welded. Thank god we didn't put it into a tree or something like that. Dropped it off at the dealer today. Not sure what can be done. He said it is a frame issue that the factory needs to get involved. Not looking good for me. Has anyone had this many problems with a new rzr?
i have 2012 rzr 4 800 as well, only reason i bought a polaris was that it was the only machine out there that had a sporty 4 seater,
it is only 6 months old and here are my issues and problems
1- right from day one i had a majior issue. Top speed was only 52 mph.
I called the dealer told them there was a problem with the rzr. They told me it was normal, so then i started to do reasearch on the problem and found out it was a problem,, but the dealer wouldnt do anything about it
2- had 2 roll cage bolts break off while out on a run, polaris replaced them
3- steady bearing went, polaris replaced it
4- primary and secondary clutches
5- and last but not least just before factory warranty was over
all 4 carrier bearings
all 4 ball joints
all front and rear a arm bushings
polaris will replace the ball joints and the carrier bearings but will only pay for 2 hrs labour
i have to replace all bushings myself
ask me if i am a polaris lover,, not !!!! ,, if they made a good machine and stood behind their product they would give you a decent warranty,, they make them to fall apart , 6 months warranty is garbage, but i love the look of it
,, the rzr that is ,, i use mine alot, in 6 months i got 3900 miles on it to date,, no mud no rocks, only logging roads and old rail way at high speeds,,
