2011 rzr 800s low top speed
1 reading
5.4K views 11 replies 4 participants last post by  rijoh2000
I have a 2011 rzr 800S which is topping out at 50mph machine has snorkels 28” mud tires and 1000xp 14” wheels stock clutching an oem belt machine has 190psi in one cylinder and the other has 200psi but only getting 5500rpm out of the machine
Rev limiter kicks in at 6500 rpm so most clutch tuners target around 6200-6300 rpm. If you have stock clutching it is not matching your tires and wheels which are heavier than stock. To correct for this, you would need to go with lighter clutch flyweights or go with a stiffer primary clutch spring. Although you could buy separate components, you are better off buying an adjustable kit from a reputable company.
A fuel tuner for an 800 would not give you a performance increase like it does for the 900's & 1000's. It would simply be used to increase or decrease fueling and should only be used if something else has changed such as a turbo, or big bore or high flow exhaust etc.
That said, if you were to increase your HP you would rev more. And there are situations where the added HP may put you over the 6500 rev limit. For example a turbo would do this and you would need to add weight to your clutch flyweights to bring the RPM's down back into safe range.
If you have a stock clutch with those bigger tires, an adjustable kit will increase your performance as it gets your RPM's back into a better power range. It is your best bang for the buck.
