2010 rzr 800s ticking in the topend
11K views 7 replies 4 participants last post by  trglenn
can anyone tell me what this ticking could be i have rebuilt this entire engine with new oem crank,cam and lifters,all new bearings new oem oil pump,new rocker arms and push rods, new pistons cylinder and rings .i have an oil gauge hooked up and cold idle is around 75psi and warmed up is around 10-12 at idle and warm with rpms at 5000 it stays at around 70psi im using ps4 oil and Polaris filter that was just changed before the video link i attached. does anyone have an idea what this could be
Maybe it's just my computer speakers not conveying the sound properly, but it sounds like a RZR800 motor. Slight rattle noise. How many hours on the motor after rebuild? Using High Zinc break in oil?
The motor sounds "normal" for an 800. The rocker arms shouldn't have any slop in them, it's cam driven lifters to push rods, there's no adjustment. I was told these cams can "go flat" and the lifters should have been primed from the factory. So not really much you can do but replace parts. Regardless, the noise you are hearing is normal 800 operation. They rattle. They don't run smooth like a fancy new motor. They are the cromagnon of the side x side world motor.
Hard to hear the actual motor, but here's our freshly rebuilt Rev6 motor... the Big Gun Exhaust makes it harder to hear the motor, but it's got that noise you're hearing.
Right after we put the motor in:
https://www.instagram.com/p/ByyvjJvnsRL/?utm_source=ig_web_copy_link
With 99% back together:
https://www.instagram.com/p/BzB_VfmhCVw/?utm_source=ig_web_copy_link
Did you use new cam when rebuilding? The motors are loud and rattle a lot. Sounds like a RZR800. Check our YouTube or insta to hear ours. Keep checking that oil level too!
