170 Aftermarket Wish List - Hint, Hint!!!!
3.9K views 8 replies 4 participants last post by  bilinvic
I figured I'd put this out there for the aftermarket industry to think about producing some "goodies" for the RZR 170. Feel free to add to this list and hopefully the aftermarket folks will fulfill our wants!!!!
1. 1.5 / 2.0 inch lift kit (for obvious reasons)
2. Tubular nerf bars so the kiddies will not crack up the midsection plastics. There's already 3 bolts on each side that could easily be incorporated for this. They don't have to come up from the bottom....more or less a rub bar.
3. Rear bumper that comes down from either the top or lower rear roll bar and continues down to the mid rear section. Again, bolts are already in place as attachment points. They could even use the mounts that the rear mesh bag uses. (remove the bag and support bar)
4. Sprockets....either smaller front or larger rear to compensate for larger rims and rubber.
5. CDI....revised with higher rev limits or non-limiting.
6. Jet Kit
7. Hi-Performance exhaust
8. Tailights.....real ones!!!!
That's all I can think of right now....I'm sure I will think of more later. There's items I didn't list because they are already produced, such as skids, 4-point belts, billet exhaust tip (EBAY).
I didn't mention an air filter, because this evening I created my own UNI filter for the 170. Just buy some bulk UNI foam filter media, use the OEM filter as a template and cut to size. I oiled my new UNI filter up and now I'm good to go.
What do y'all think of what I've listed?
I look forward to seeing what you come up with...
I'm not sure about the sway bar since the rear is a solid rear axle. I just bolted on 1.5" billet spacers on the rear and in combination of the 11 inch tires, my little RZR is now 51.75 inches wide. I'm sure it will be very stable now!
I didn't need any spacers...everything fit great. Although, I did go with 3+2 front rims to get the calipers tucked into the rim. What style of wheels did you go with? What kind of tires?
Please post pics when you get them bolted on....I would like to see what the 22x8-10s look like on the front.
I'll get some pics up soon with the additional 3" width on the rears. Looks very kool!!!!!!
