17 RZR 4 900
1.8K views 1 reply 2 participants last post by  SuperATV
I have a 17 RZR 4 900 I am still getting some vibration from prop shaft while in 4 wd I replaced the carrier bearing with Sand Craft replaced all 3 u joints Im guessing the only other part is the prop shaft. I have GDP 4 portals with 30 % gear reduction I'm wanting to use the SATV bounty series. Anyone have any idea if it could be a different problem an is anyone running the SATV prop shaft have any issues so far I've haven't had any problems with any parts I've used from SATV
For you, I'd recommend the C-series CV prop shafts. You'll eliminate any possible vibration in the driveline that way. You will be required to use our carrier with our props, but the cast is super affordable and all you'll need. If you're getting vibration after that, I'd check your pinion bearing...and maybe even check your wheel bearings just in case.
