my driverside injector is dumping a tremendous amount of fuel killing that cylinder out. it will start and run on the passenger side cylinder no problem but immediately floods the driverside cylinder and never has a chance to fire.
unplug the injectors, and fuel stops. plug the injectors back in with spark plugs out and turn the motor over only to watch the driverside begin gushing fuel up like a fountain on every compression stroke.
any thoughts? a stuck injector would spray fuel with fuel pressure regardless of command right? and it just started this today when i tried to start it, previously it was fine.
on a side note, does anyone have a part number for injectors that are available at a local parts store? polaris dealer does not carry stock injectors.
