▀▄▀▄ Vivid Racing | HCR Racing Elite OEM Replacement Suspension Kit Polaris RZR Turbo S - Polaris RZR Forum - RZR Forums.net
post #1 of 1 Old April 17th, 2019, 04:48 PM Thread Starter
vividracing's Avatar
First Name: Dan
Member #189601
View vividracing's Photo Gallery(0)
To take the already impressive RZR Turbo S one step further, HCR developed an American made product with is lighter, leaner and meaner to compliment the aggression of the new model. This kit follows HCR's blueprint of quality manufacturing, craftsmanship, unmistakable design and distinguishing features which result in a product deserving of the HCR badge.
In-house engineering and manufacturing capabilities allow HCR to immediately start design and reverse engineering the moment a new model is released. The factory design is improved by adding pocketing and internal structure to increase strength and durability while eliminating weight. The HCR signature High Clearance A-arm and trailing arm design increase ground clearance under key components. Caster/Camber settings have been embedded into the design of the suspension to eliminate the need for adjustment heims, and allow for stronger contact points.
The NEW RZR Turbo S, along with HCR's Complete line of suspension systems, is manufacturing using HCR Elite Material. This proprietary material boasts 30% stronger tensile and yield strength compared to 4130 Chromoly. The material goes through several processes and is hardened for better wear resistance and overall strength. An intensive process is used during each design to simulate and refine the geometry to match the characteristics of the stock suspension. Critical measurements are verified, such as ball joint angle, CV Joint angle, and clearance to surrounding parts to ensure no binding or interference. The quality fit and finish, ease of installation, and top shelf performance of these kits are what sets HCR Racing apart from the competition. Through intensive craftsmanship, meticulous precision and BOLD aesthetics, we strive to make HCR your #1 Choice.
Package Includes:
4 Front High Clearance A-arms (upper and lower)
2 Rear High Clearance Trailing arms
Hardware (front arm hardware, and rear say bar bolts and shock bolts, brake line hardware)
Features:
Fiber Laser Cut construction for precise fit and finish
CNC'd 4130 heat treated billet mounting points for increased integrity
Angeles catacomb design for optimal force distribution
High Clearance Boxed A-arm Design
hand TIG welded for strength and aesthetics
OEM Ball joints are reused to maximized low speed steering, ease & smooth travel with less maintenance.
Uniball Option available for racing & short course applications
Compatible with factory wheels
100% Bolt-on installation using factory mounting points
Elite System 20 pounds lighter than factory components
Fitment:
Polaris RZR Turbo S
Notes:
Kit will reuse factory ball joints or equivalent replacements, Rear trailing arm radial bearings, front A-arm mounting bolts, trailing arm mounting bolts and rear links with hardware.
All kits run 3-5 week production time and are custom built to order.
Any Questions? Please CONTACT RYAN!
CALL ME - 1.480.966.3040 x243
SHOP HERE - www.vividracing.com/utv | EMAIL ME - [email protected]
We FINANCE Parts with AFFIRM
Shop Popular Products, Click The Banner!
vividracing is offline
UTV INC Billet Sway Bar Mounts UTV Inc. UTV Inc 2 March 28th, 2019 12:17 PM
Polaris RZR Lock & Ride Poly Sport Roof- Black Item # 2883073 - $225 ashills Parts For Sale - Upper Midwest 1 January 26th, 2018 10:52 AM
Twisted Stitch & PRP Seats In Stock ! UTV Inc. UTV Inc 33 August 8th, 2017 11:35 AM
Please welcome the 2016 RZR XP Turbo EPS! Dascrow Polaris RZR News 52 September 1st, 2015 10:24 AM
Gussets galore !! UTV Inc. UTV Inc 23 August 14th, 2013 05:34 AM
