1/2 ton enough? - Polaris RZR Forum - RZR Forums.net
 16Likes
post #1 of 25 Old July 19th, 2017, 12:44 PM Thread Starter
Illtater8's Avatar
My RZR: 2017 Rzr 1000S
Member #181386
View Illtater8's Photo Gallery(0)
1/2 ton enough?
I figured this would be the best place to get answers from real users. I would like to go from my 18" open trailer to an enclosed. I am hauling a Rzr and 2 utility atvs. I usually will be hauling the RZR and a Sportsman Touring , but will occasionally include a King quad. We are mainly in the midwest, but would like to ride in the western part of the country. I plan to free up some garage space, by using it to store them. For now, I really want to keep my 2011 Ram 1500. It has every whistle and bell, including the tow package and brake controller. I am currently looking at a 7'x29' all alum snowmobile trailer, with 12" extra height. It is essentially a 24' box with a 5' Vee nose. Curb weight of 2600# and max of 7000#. Every dealer says I should have no problem handling the trailer with my truck. In real life, would this be the case? My tow rating is 8600#, but I don't really want to be dragging butt either. Has any one had any experience with a 1/2 ton pulling this type of trailer?
Illtater8 is offline
post #2 of 25 Old July 19th, 2017, 12:54 PM
tystang2001's Avatar
My RZR: 2011 rzr 900xp, 2017 rzr 4xp1000
Member #173625
View tystang2001's Photo Gallery(0)
Re: 1/2 ton enough?
While one of my trailers are smaller than the one you are considering I have weighted it down as much as yours would be and pulled it with my 1/2 ton SUV and did not have any troubles.
Illtater8 likes this.
tystang2001 is offline
post #3 of 25 Old July 19th, 2017, 04:00 PM
XR4Honda's Avatar
My RZR: 2008 RZR, Rear Bench for my 2 boys
Member #13135
View XR4Honda's Photo Gallery(0)
Re: 1/2 ton enough?
Weight wise you will be fine. Your MPG will be around 8-9 because it's big and tall which equal a lot of wind drag.
XR4Honda is offline
post #4 of 25 Old July 19th, 2017, 04:15 PM
oldsman41's Avatar
First Name: don
My RZR: 2017 900 trail
Member #79101
View oldsman41's Photo Gallery(0)
Re: 1/2 ton enough?
been there done that i towed a 26 with a race car and the tools plus my motors. weighed in right at 8200 lbs had a hemi half ton it pulled ok but no rocket mileage was horrible most the time 7 mpg.
oldsman41 is offline
post #5 of 25 Old July 19th, 2017, 06:20 PM
rbpower's Avatar
My RZR: 16 RZR turbo, 16 Ace 900, 17 sportsman 110, 16 tarex4, 12 sportsman 500HO
Member #163113
View rbpower's Photo Gallery(0)
Re: 1/2 ton enough?
i would say your ok.. for the limited amount of miles you will be using it to haul the trailer the difference in fuel cost to the cost of a bigger truck that would get maybe 15mpg does not justify expence of the new truck..
Vandal and Illtater8 like this.
rbpower is offline
post #6 of 25 Old July 20th, 2017, 06:56 AM Thread Starter
Illtater8's Avatar
Member #181386
Re: 1/2 ton enough?
Thanks guys. I figured my mpg would be poor, but its better than a truck payment. My next one will be a diesel anyways. I didn't want to abuse the one I have, or have the hitch dragging on the ground. The trailer I'm looking at is a left over 17, marked down to 7100, from 10500. So the extra length is pretty inexpensive, but have to be able to pull it.
post #7 of 25 Old July 20th, 2017, 07:13 AM
m00s3's Avatar
Member #201777
View m00s3's Photo Gallery(0)
Re: 1/2 ton enough?
You won't have any issues. Just costs Gas. Well within the limits of a 1/2.
m00s3 is offline
post #8 of 25 Old July 20th, 2017, 07:44 AM
flbluerunner's Avatar
My RZR: 2014 RZR XP 1000
Member #17226
View flbluerunner's Photo Gallery(0)
Re: 1/2 ton enough?
You should not have any problems. Tow my 17 foot enclosed with a full sized motorcycle in the front V and the RZR XP backed in to balance the tongue weight.
Use a 1500 Yukon without issue, mostly towing in the mountains of CO.
Definitely have to slow down when climbing one of the high passes.
Cuts my economy to about 9 1/2 GPH.
flbluerunner is offline
post #9 of 25 Old July 20th, 2017, 09:17 AM
Lollygagger77's Avatar
Member #84887
View Lollygagger77's Photo Gallery(0)
Re: 1/2 ton enough?
I pull a 35 foot 8000+# travel trailer with no issues at all with my Ram 1500, So you should be just fine! If you don't have the air ride suspension I recommend air bags to put in the rear coil springs. Really help stabilize everything!
LHartman and Illtater8 like this.
Current Rides: 2018 XPT4 Orange
Old Rides - 2016 RZR 900S EPS, Sportsmans : 2012 850 HO EPS, 2000 500, 2003 500HO, 2005 700, 2006 800
Lollygagger77 is offline
post #10 of 25 Old July 20th, 2017, 11:04 AM Thread Starter
Illtater8's Avatar
Member #181386
Re: 1/2 ton enough?
I don't have the air ride. I think it came out in 12 or 13. I'l have to look in to that,
post #11 of 25 Old July 20th, 2017, 01:56 PM
JDeere7296's Avatar
Member #111697
View JDeere7296's Photo Gallery(0)
Re: 1/2 ton enough?
You can get the firestone Ride Rite air bags, that will help out tremendously on your rear suspension squat and level out your load. Plus it will save the heavy compression on your leaf springs which over time will flatten them out. I just priced a set for my 2014 Silverado and it's like $345 and it says takes about an hour install time.
2013 RZR 4 - ProArmor doors, Protop roof, 28" Moto MTC tires, SuperATV winch & Wild Boar bumper, Racertech HD springs & Dalton Clutch Kit.
2017 RZR 1000 Highlifter Edition - Shock Therapy rear tender springs, Walker Evans Links, Dalton Clutch Kit, Rockford Sub, & Powerbase Sound bar.
JDeere7296 is offline
post #12 of 25 Old July 20th, 2017, 05:06 PM
Iamallard's Avatar
My RZR: 2015 RZR 900 Trail EPS
Member #57821
View Iamallard's Photo Gallery(0)
Re: 1/2 ton enough?
I think mfg tow rating states you must use a weight distributing hitch for trailers over 5 or 6 thousand lbs. look in your owners manual. Air bags will not transfer any weight to the front which you will want to make it handle way better. All 1/2 tons I've seen pulling long bumper pull campers have weight distributing hitches.
Iamallard is offline
post #13 of 25 Old July 20th, 2017, 05:44 PM
Vandal
Vandal's Avatar
First Name: Richard
My RZR: 2016 RZR 570 EPS Trail
Member #82526
View Vandal's Photo Gallery(0)
Re: 1/2 ton enough?
The OP doesn't have any leaf springs The 2011 dodge has coils on all 4 corners
Vandal is offline
post #14 of 25 Old July 20th, 2017, 07:04 PM
gtsum2's Avatar
Member #72995
View gtsum2's Photo Gallery(0)
1/2 ton enough?
Would strongly recommend a wd/anti sway bar. I had a 2013 ram 1500 for one year and towed quite a bit (less trailer than u r looking at). Hemi has power, but the rear suspension is terribly soft. Ram half tons have the worst payload rating of the big three trucks (check your door jam...I bet u have less than 1400lbs payload capacity on your truck...mine was a loaded Laramie and mine had 1061lbs...terrible!). Air bags do nothing to increase that number either. I hated the squishy suspension when towing and ordered a ram 3500 cummins after owning the 1500 for a year....problem solved
Sent from my iPhone using Tapatalk Pro
2016 RZR 1000s - Sold
gtsum2 is offline
post #15 of 25 Old July 20th, 2017, 07:27 PM
SpeedQuest's Avatar
Member #205121
View SpeedQuest's Photo Gallery(0)
Re: 1/2 ton enough?
Been there done that... I'd opt for at least a 3/4 ton to do things safely. Or put a 3/4 ton suspension in your 2011 Dodge.
SpeedQuest is offline
Please help, which toy hauler? turbo_kieran Tow Rigs, Trailers and Camping 118 July 5th, 2019 12:44 AM
Anyone carry their Taril in a 1/2 ton PU? ID-Rzr RZR 900 - 50'' Trail Models 10 June 26th, 2016 12:04 PM
1/2 Windshield fitment ... bigjeepman General RZR Discussion 1 April 24th, 2016 07:28 AM
2005 Keystone Tailgator Toy hauler 1/2 ton towable xp1k4 will fit Ballzout Misc For Sale 20 February 11th, 2016 08:18 PM
XP1000 1/2 Windshield XP4XV Polaris RZR Parts For Sale 1 January 3rd, 2016 05:14 PM
