RZR Front Inner Fender Armor - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 17 Old May 7th, 2016, 06:27 AM
Fastone110's Avatar
First Name: Travis
My RZR: 2016 1000s
Member #31197
Re: RZR Front Inner Fender Armor
Max tire size with out rubbing?
Sent from my XT1254 using Tapatalk
Fastone110 is offline
post #17 of 17 Old May 7th, 2016, 09:06 AM Thread Starter
Thunderhawk's Avatar
First Name: Harry
Member #684
View Thunderhawk's Photo Gallery(0)
That's really difficult to say. Honestly, I could not simply say that any thirty-x inch tall tire fits, as a blanket statement. Most tires from different manufacturers measure different from their sidewall sizing, and the tire profile would also affect clearance from one tire brand to the next. Different wheel widths affect tire diameter and wheel offsets also affect tire clearance. For example - the guys running 4+3 wheels on the front have their tire centerline moved out 1" farther than on a 5+2 wheel, but the 4+3 wheel causes the tire to swing in an arc (moving the wheel & tire forward and rearward a bit when turned).
I will start to check with current customers to build a database of wheel and tires combos used. This should give a good idea of what is being used with the inner fender armor kit, and allow for comparisons using tire manufacturers specs from one brand to another.
In the mean-time, I can state that this inner fender armor kit uses from zero to approx 1/2" of space (when compared to just the plastic floor-boards) in the areas where possible tire clearance could be an issue. If you already have your tires, you could check your current clearance and verify that you have 1/2" available. If it's close, give us a call. If you're looking to buy new tires, then that's a little more difficult. In general, I'd say that buying 1" smaller should guarantee clearance.
Thanks,
Harry
E-mail: [email protected]
Thunderhawk Performance, Inc.
www.thunderhawkperformance.com
Phone: (216) 965-4800
Thunderhawk is offline
