1 - 7 of 7 Posts
I installed the new Zbroz dual rate spring kit on my RZR Turbo R Dynamix 2 seater the weekend before last and then got out for a ride yesterday. You can check out what's been done to my RZR here. We drove down to the 4 Mile area by Buena Vista Colorado which has a little bit of everything from a terrain perspective. The main trail out of the parking lot is relatively smooth but fast and twisty with a bunch of small natural jumps that would give a stock RZR 800 or XP 1000 suspension SERIOUS BUCKING fits (if you know you know!). From there, the main trail turns into a sand wash that is great for flat out blasts of speed but not much of a challenge for any suspension. We then connected up to a trail called Chinaman Gulch which has some nice technical rock crawling areas. After that we connected back up to the Bald mountain loop trail which has a steady hill climb up to near tree line (~9500'). It's not too steep but like any trail at that altitude, it's just rough and rocky, low range max ~20mph.
For the first section of trail (fast and twisty with small natural jumps), the new springs were immediately noticeable. They are much more plush at the bottom of the stroke than the stock springs and then stiffen to resist bottoming when they crossover to the main spring as you would expect from a dual rate spring stack. They actually feel like a dual rate spring pack should now. Even though the stock springs were supposed to be dual rate on the Turbo R, I never could feel any rate change. They just felt very linear throughout the stroke to me and too harsh from the bottom to the top. I only had about 250 miles on the stock springs but they seemed to be getting more harsh as the miles went on. While the stock Turbo R springs didn't seem to be as bad as stock XP 1000/Turbo/Turbo S springs, after having aftermarket springs in the past, I felt there was room for a lot improvement and I wasn't wrong. As a lot of you know, jumps in a stock RZR can be a bit of a mixed bag, after hitting a few jumps with the Zbroz springs, my confidence started to go up tremendously and I found myself really enjoying jumps more than ever before. I started hitting the jumps as fast as I possibly could with my only worry being how much room I had to land. And the landings were probably the best part! The machine just lands SO smooth now. Where before there was still a sense of needing to brace for landing impact, that is gone. I was using track mode out of habit when we took this trail in the morning but on he way back to the trucks at the end of the day, I put the Dynamix in Baja mode. Before the spring kit, I found Baja mode to be almost unusable due to how harsh the ride was, now Baja mode is freaking awesome! It is totally usable now with the new springs. When you are hitting the trail as hard as you can, Baja mode is now the way to go. It's much more plush down low but gives you the compression damping to worry less about remembering to hit the "oh sh*t" button on G-outs and jumps. I was bummed I waited until the end of the day to try Baja mode.
Now for the rock crawling on Chinaman Gulch, the main benefit I see is the increased flex. I did remove my front sway bar a while back, and that made a big difference, but the Zbroz springs took it up another notch. The softer rate at the low end is a very noticeable step forward in flex. Dynamix Comfort mode is not bad in the rocks but I really started paying attention to what Dynamix "Rock" mode was doing for the car. Having done a lot of Jeeping in the past, I always missed the solid front axle in rock crawling situations in a RZR but yesterday was the first time I felt the IFS on the RZR was darn near on par with the flex of a SFA. Before the spring kit, the few times I tried "Rock" mode, the suspension just felt stiffer to me and not a lot different from "Track" or "Baja" mode on the rocks. Now with the sway bar pulled and the spring kit, Rock mode very obviously keeps the chassis of the car more level on off camber situations allowing much more "stuff" on the front wheels when needed. I pulled one of my front tires up on my buddy's 30" tire on his X3 and the chassis of the car stays almost level with all 4 tires feeling planted, no tippiness. Very nice. I should have taken a picture though.
On the last terrain style, the rough rocky hill climb to the top of Bald Mountain, again I was pleased with the springs. In comfort mode, the springs just make the rough trail smoother. There's not much else to say here other than this is where your wife will approve the most of the purchase :D
If I can say anything negative at all, the recommended baseline crossover settings might be a little too high (meaning too much tender travel before crossing over to the main spring). I could see if you were racing the Baja or similar, doing 80-100 MPH through open desert and hitting whoops bumps and G-outs at speed, you might need to lower the crossover rings closer to the spring divider so you are hitting the main spring earlier. I didn't have any problems bottoming the suspension out on these trails we rode yesterday but there were a few spots on the trail where I hit the "Oh sh*t" button to make sure I didn't. This Turbo R has so much freaking travel I kept expecting I was going to bottom out but didn't actually do it. I'll post more updates here as I get more miles on them.
As of now, we are in the middle of Zbroz's 2022 black Friday sale, you can use code ZBBF15 on our website for 15% off and free shipping. Check out all the Zbroz spring kits on our website here: Spring Kits
Here are a few pics from the ride yesterday:
The start of the day and the cleanest the springs will ever be again ha.
Tire Wheel Vehicle Hood Plant
I screen shotted this from a video so it is a little grainy but you can see the right front starting to stuff up pretty nicely.
Tire Wheel Vehicle Automotive tire Car
Just thought this pic was cool with the Peaks in the background
Tire Wheel Vehicle Car Hood
The top of Bald Mountain with amazing views of Mt Antero, the Collegiate peaks and Buena Vista off to the right.
Tire Wheel Sky Mountain Vehicle
Some decent flex here coming down a rock face with the chassis still nice and level.
Tire Wheel Vehicle Plant Sky
I have a Turbo R ordered. No idea when or if I will see it.
So I’m trying to figure out a few things here if I do take delivery in the future.
Previously I had a 17XPT with Walker Links on all 4 corners. Stock Fox Shox re valved and re sprung. I loved the setup especially the Walker links at all 4 corners.
Removing the front sway bar does not mess with the sensors in the Dynamix setup?
Resulting in scrambling signals to the main brain?
Or is this system just not that advanced that removing a main component for controlling body roll has any affect on how it is reading and sensing the roll?
If you left the front bar on and used Rock mode with the new springs. Do you think articulation would be improved over the stock springs?
I’m just trying to figure out what rock mode is meant to provide if you didn’t like it with stock setup. Seems Rock mode would be there to create more articulation?
And wondering if it might provide a similar feel and setup I had with WL’s on all 4 corners?
Discussion Starter · #3 · (Edited)
@RickRou56 no issues with Dynamix removing the sway bar. I had seen where several others had done it without issue already before I tried it. I had it removed on my Turbo S with Dynamix too. Dynamix should stiffen the outer shocks in a turn if it sees more body roll but it doesn't seem to be a problem for Dynamix to do that without the sway bar. There are definitely no sensors on the sway bar itself. I think it uses a combination of roll/pitch, speed and steering angle to determine when to apply more compression damping.
If you haven't seen this out of the owner's manual:
Font Material property Parallel Document Publication
I think the main idea of what it tries to do in Rock mode is to keep the tires on the ground and the chassis more level by softening the suspension for the wheels on the highest rocks and stiffening on the wheels sagging the most. Before the sway bar was removed, Comfort mode just felt like it flexed more in the rocks than Rock mode. I really had stopped using Rock mode for that reason.
I am certain just the spring kit would improve flex some but the front sway bar just seemed really stiff in this thing. When I saw this photo from our trip to Wheeler lake, I knew I had to pull the sway bar. I don't remember if I was in Rock mode or Comfort mode in this photo but either way, there should be way more flex than this!
Tire Wheel Plant Sky Vehicle
Yes. My XPT was like that picture before springs and Walker Links.
The front Walker Links made a huge difference.
I think if I take delivery I will try the Zbroz kit.
I can determine sway bar from that point.
What’s funny is everyone says Polaris puts a basic spring kit on these as an all around package.
But Zbroz, G Force, ST, RT, can create a kit that works for everyone……in a good way.
1 - 7 of 7 Posts
