21 - 40 of 66 Posts
I think this picture has 30s, soon after I changed to 32s.
I'm running 15" wheels and also have the control arms that push the front wheels forward a couple inches.
I get slight rubbing on back of the fender at full lock/stuff and a little on the top of the fender flares.
Love it with the 32's.
Sent from my Nexus 6P using Tapatalk
Did you adjust your clutching at all after you went to 32s?
I actually did it when I installed the 30's.
Thinking it was Hunter Works kit. Would need to go through my paper work to verify.
I didn't notice any different between the stock tires and the 32's with the clutch work.
Well, maybe a slight power loss.
Experienced on a Sand Hill with 4 people in it. Made it over the top but I could tell the was a slight loss of power.
I would just get the plus a-arms and get some heavier springs to increase your ride height some over stock. I am not a fan of lift kits. Most of them just seem to move the upper shock mount down which is pretty cheesy. You can easily gain a couple inches of ride height with and Eibach Stage 3 spring kit.
good advice right here
X3 Buddy of mine had a kit taken off his that I picked up cheap. After bolting it on I gained me a few inches ( thats all I wanted ) your height is gained more buy adjusting the shocks than the reposition of the shock. I will get the springs to do it ( IMO ) the right way when $$ allows . Most of our riding is in tight woods and the 4 seaters gain a lot from the extra clearance.
Any lift kit that changes the geometry is going to affect the ride. I ran the highlifter kit pictured earlier on a 2014 XP41000 and it rode like $hit afterwards. Harsh ride, bad roll, loose in corners. I took some preload out of the springs which helped some but then I lost the clearance I gained. Great kit for tire clearance and the mud which it was designed for but the ride manners on the trail were terrible.
I love the 4 seater but, I get high centered and rub the chassis way to much...so I hear ya.
Eibach Stage 3 springs really helped with my ride height. Given I still have to watch certain places with the long wheel base, I don't have nearly the problems that I had stock. With my RZR empty, I have about 15" of clearance in the front and 14" in the back. That is with 30" tires.
I am really thinking strongly of upgrading to 32" Pro Armor crawlers. I have a Racertech lift and love it!! My question is this. Do I need to do clutch work as well or can I leave it stock?
I bought 32" Outback maxs on a 17" wheel, 3-5 bracket lift, Dalton clutch, arched arms and radius rods. Should have it back this weekend with the clutch and lift installed. Arms and rods ate in transit. I'm pretty stoked.
Whether you need clutch work or not depends on how performance oriented you are. If you are just a mellow trail rider then no, you probably won't need to mess with the clutch. If you want the most performance possible, you are leaving a lot on the table by running 32s and stock clutching. I would call Sparks or Airdam and have them put together a custom kit for your RZR/application.
21 - 40 of 66 Posts
