Hello,
I'm about ready to order your clutch kit but before I do, I've got a couple questions:
1) Does your kit reduce or eliminate engine braking? Is there a choice when ordering? I would at a minimum like to significantly reduce this effect.
I do a lot of open desert riding and I do not like when the rear tires leave the ground, I get a "jerky" feeling when the tires make contact again. Will your kit eliminate this?
2) The stock set up seems a bit sluggish off the line, will this kit improve take off performance? Otherwise, stock clutching seems OK.
(Currently this car tops out at 72-74ish or so and do not anticipate any top end performance changes)
Thanks
Thanks
