Hi guys, thanks for all the great info. Finally have something to post about myself.
I bought a used 2011 XP LE with about 1800m on it. Less than 50 miles later the engine, at 40mph, momentarily lost power (felt like a rev limiter) then regained - backed off the throttle to idle and lost power / horrible noises, seize.
6 hours later i was able to recover the RZR from the bush (after tearing out the front end of my 4x4 - expensive day :/ ). Tear down showed 1 cylinder ok, the other had 2 broken valve heads sitting on top of a very damaged piston. The other 2 valves bent bad. Cylinder wall cracked, head destroyed.
So needless to say I need some parts if anyone happens to have head or cylinder lying around, however I'm in a bit of a quandary here because I can't figure out how this type of failure occurred sooo what stops it from eating another bunch of parts when I reassemble?
How does 1 side loose all its valves, no springs broken, cams not abnormally worn, while the other side remains kosher? I checked the intake / exhaust on that side for ingestion of debris, but air cleaner remains in good shape and intact with nothing foreign past that point. Buckets not binding or worn either.
Obviously I'm a little upset about my 15K machine lasting about 2hrs, but I bought used, and it is what it is. To go forward I'd sure like to know what happened here. I'm comfortable inside an engine, but certainly not an expert, and with I've read here, there'd be a few experts around. Would love to hear any opinions comments or parts offers.
Thanks.
(will try and post pics)
:scared2:
Thanks.
:scared2:
