Xp or turbo problem?
23K views 197 replies 29 participants last post by  35thconvertible
Okay, I have a K&T turbo, stock bore/piston ect. 10lbs. Race gas. KT intake manifold, and BOV. Problem is when I start the machine (cold)the afr reads lean (13/14.5). So I can adjust idle fuel on pure logic to 4 and I'm good (12.5 afr). I can let it warm up, take it for a spin, and somewhere around 20mph or half throttle my afr goes rich. It drops to 10.4 at idle, 10.8 while driving. It will stay there for as long as I ride. I then will adjust my box all the way down to get 10.8 idle, 11 driving. If I stop and let it cool down, I'm back to lean start up, and adjusting the pure logic back up to grn/y/rd all on 4. And do this all over again as it gets to speed. The guys at K&T have bent over backwards for me trying to figure this out. We have changed the IAC valve, ECU, fuel box, put on a fuel pressure reg, even bought a pcV w/auto tune. Still no luck. We're thinking maybe the TPS? So Rayce is getting me a throttle body(with TPS) to try out. Ive went over everything. All lines look good. No vacuum leaks, hell I don't know. Any ideas? Any help or ideas would be very appreciated.
X2, I have had a couple o2 censors run me in circles. With your machine running grab the wires right at the o2 censor and wiggle them.....I have had the wires go open at the censor as well........
Let us know what the fix is, I am sure it will be something simple.
When it drops to 10.4 does it run crappy? How is it under load?
I really don't look at my af gauge too much...just once in a while when I'm pushing it hard to make sure it isn't running to lean~ 13. If it is too rich under 10.5 then it bogs down.
Just tune it...and as long as it isn't running too lean...then you should be fine...unless it is physically bogging down.
WOT is most important...when you are going slow and letting off and on the gas you will see some weird numbers for split seconds. The digital gauges makes you more worried than a needle sometimes.
#15 ·
If I walk in the garage right know and start it up,with the setting on the pure logic set as I left them(light fast blinking off) it will hardly idle. The afr is 15ish and as it warms up, it moves to 13/14. I then bring the idle fuel up to 4/5 and the idle smooths out and picks up(12.5). All seems good. I can back out of my garage say 40ft, gas it back in my garage and it goes to 10.2/10.4 at idle. How can I tune for that? It does run weak upon becoming rich. After a while the plugs will foul, I tried to just run it at 10.2/10.4, and went through a few set of plugs. It seems electrical. Some sort of sensor, at a certain speed/throttle position, everytime. Maybe at boost, im at a loss. Thanks for the replies.
#20 ·
Have you checked the wires going to your extra injectors? You might have gottem oil on the MAQS....
Seems related to the pure logic or injectors. It should run the same at idle...there really isn't anymore fuel going into the motor at idle than on a car without boost since you are making no boost at idle. Sounds like after you gas it and make boost the computer is still adding extra fuel.
#23 ·
You got a good point. I have checked the third injectors. I disconnected them and made a run. Same thing. But I'm like you, it seems the be fuel box, but I've changed it out already. I usually don't post much, but this one has me asking for help! This has been an every night thing for two months.....
#25 ·
Milos, that's why I bought the pcv w/ autotune. I thought the same thing. But after trying to set up the pcv and giving it a target, it does no good if its changing constantly. I talked to mike at RPM, he agrees that I need to find the root of the problem before the pcv and autotune will work properly. I changed a regulator in the tank and put a adjustable regulator at the fuel rail.
St10, I also thought of this. So I let it idle for a while, (after it was cold) getting the temp up. It gets to 200 deg. Still a good afr 12.5. Then go for a ride and about 20/30mph bam. Back to 10.2/10.4. So if it were temp it should of corrected after a long warming idle. This brings me to think something triggers boost/ TPS / volts.
#30 ·
JC, I took the pcv off for now. I'm back to the pure logic. I have hooked everything electronically back to stock, just to see. It is way to lean to drive. 15/16 afr hardly idles. So I can't tell much from that test. Rayce and randy both said its not right. So I'm not giving up yet. I shouldnt have to constantly adjust the fuel box. If it ran good I Possibly could live with it. I'm also having a problem getting enough fuel at wot with the fuel pressure turned up(38psi). I have to turn the fuel pressure down to get the afr in the low tens. Catch 22
#129 ·
JC, I have hooked everything electronically back to stock, just to see. It is way to lean to drive. 15/16 afr hardly idles. So I can't tell much from that test. Rayce and randy both said its not right. 22
Put my rzr back close to stock, and it still acting up. So its Not the K&t kit. I believe the ECU get readings from various sensor and adjust accordingly. So I think I might have a bad sensor somewhere else. So I'm going to order every sensor( other than TPS) and change them out. I hope this does the trick, I'm out of ideas..... I did read in the service manual that the speed sensor tells the ECU vital info on how and when to add fuel. But if I had a screwed up sensor wouldn't it throw a check engine light??
...remove the turbo kit all together start stock....bone stock...
X2
Lets not go backwards guys.
He's already gone back to stock and still has the problem, with boost tube disconnected and all controls back to stock.
IMO and others on this thread...
Probably related to oem cold engine enrichment not working correctly because of faulty sensors or electrical connections.
JFYI, almost all piggyback fuel controllers only can add fuel. They can't make idle afr leaner than stock oem... impossible to do with them. The one exception to this is the The Power Commander, PCV, the only engine controller that can make it leaner than oem, if I 'm not mistaken.
#31 · (Edited)
head gasket?????
I had a lean then rich engine problem once that turned out to be a bad head gasket, under boost my AFR was spot on but at idle or just cruising it would lean out because it was sucking in air without a little bit of boost pressure to hide the leak………. Prob doesn’t fit your situation but I thought I would throw it out there for thought.
