Xp 4 1000 blowing key fuse HELP!
14K views 23 replies 11 participants last post by  Marty Sharpless
Ok this is driving me nuts. I have a 16 xp 1k rzr with less than 15 hours on it. The bike keeps blowing the 10a key fuse. I took it to dealership and of course it didn't do it there. Here is the thing. It only does it in high gear. I thought maybe it was a rpm thing but even when I rev it high in low it doesn't blow. When this fuse blows it completely shuts the bike off till a new fuse is put in. I have blown over 12 fuses. Now it does seem to happen in wet conditions. It started when I was riding in the rain and now there is snow on the ground. I am at a total loss with this and don't even want to take it out cause of this issue. Can someone please get me started in the right direction?
I also put a winch on and ran a factory harness to the buss bar under the hood. This is where I hooked the light bar up to as well. This is connected straight to the battery so this leads me to believe it's not even tied into the system. I could disconnect it but don't think it will matter. No the bike wasn't doing this before the fog lights or light bar but also put 75 miles on it afterwards and never had a problem. The owners manual says the key fuse is tied into gauge, efi relay coil, eps relay coil, and key switch. I just don't understand how it does it in high gear only. I wish I had a wire diagram to track all these to check wires and grounds.
Someone else can chime in as well, but I think that's where you problem is tying it on to the factory buss bar. You may be overloading it. If you haven't you should install a separate distribution box since you already have a separate power source coming from the battery.
It can't be. The winch comes with a separate oem harness that goes strait to the battery to the buss bar. So the only things on that circuit is the winch and light bar that go straight to the battery. And the fuse blows only in high gear with light bar and winch off. Both of these are completely separate from the rest of the bikes electrical system except being tied to the battery.
Ok disconnected the buss cables going to battery from winch and light bar and the wires going to the accessory post from the buss. I also pulled the head light fuse to take them out of the equation as well. Took it for a spin not even a half mile and blew 2 key fuses in high gear and then I blew one for the first time in low gear. I wonder if it's the voltage rectifier? The D.C. On gauge is reading 14.1-14.3 when running.
#20 ·
I have been talking with dealer and they have emailed Polaris to see what they comeback with. I would just rather fix it myself if I can to alleviate having to take it to them and the time for them to fix it. I'm a certified aircraft mechanic and rather do the work myself and have them pay for the parts if needed. I just don't have the test equipment to test all these atv parts.
#22 ·
ok since it was still under the 6mo warranty they covered it. I felt like I knew more about this stuff than their own mechanics. Anyway. Every time I took it to them it stopped. I think it was moisture related and only did it after getting wet. So I had to take it back to them multiple times and took the blown fuses to them to. I had about 15 of them. Then I had to drive it with them in it till I got the headlight to flicker and the govenor kicked with seat belt on. Anyway I told them the only thing I could find on line of the same issue was they replaced the whole wiring harness of the bike and they did and I have taken it out 3 times and haven't had any issues. Hope ur still in the 6mo warranty and bought the extended warranty. The Harnes cost 950$.
