1 - 5 of 5 Posts
1997 30th Anniversary Edition Z-28 SS Camaro
#18 of 957 cars built
52,000 original miles.
GENERAL INFO
-Lowered
-All white, Stock orange racing stripes removed
-T-tops.
-1/4 mile time = 12.2 @ 109MPH
-Original Paint-No winters
-All the bells and whistles
-This is a Daily Driver on premium pump gas.
FRONT SUSPENSION
- BMR Fabrication Tubular upper and lower control arms
- BMR Fabrication Tubular K-frame
-Adjustable Koni coilover shocks
- BMR Fabrication front sway bar
-Strut tower brace
REAR SUSPENSION
-BMR Fabrication Tubular control arms and panhard bar
- BMR Fabrication trackbar 1/2 the length of stock, with pinion angle adjustment.
- BMR Fabrication Subframe connectors.
- BMR Fabrication rear swaybar.
-Koni adjustable shocks.
-Rear lower control arm mounts lowered 3 inches from rear end to keep correct control arm angle after lowering.
TIRES
-Front Yokohama A520 275-40-ZR17
-Rear Nitto Extreme Drag NT55R 315-35-17
BRAKES
-12.5" Slotted front rotors with 6-Piston Wilwood Calipers.
-Stainless Steel Braided front brake hoses.
-Wilwood rear brake pads.
-Line-Lock for rear Brakes.
ENGINE
-350 LT1 400+HP
-K&N Air intake.
-LT4 Intake, Hand ported to match the hand ported Canfield Aluminum Heads.
-GM Hotcams Full roller Camshaft.
-Competition Cams full roller rockers.
- 22lb injectors
-Bosch high performance fuel pump
-Meziere Enterprises electric water pump.
-High Output polished Alternator.
-MSD Distributor.
TRANSMISSION
-Fully Built 4L60E Automatic
-2800 Stall Torque Converter
-B&M Shift kit
-Heavy Duty aftermarket Trans cooler.
-Aluminum Driveshaft.
COMPUTER
-1995 GM 5.7L- pre rear O2 Sensor. Tuned with LT-1 Edit software
EXHAUST
-Hooker SuperComp full length headers, Powdercoated Silver.
-3" Mandrel Bent Y-Pipe.
-3" Mandrel Bent Pipe to muffler. (Muffler Cut-out just before rear end)
-High flow Muffler with Two 2.5" tailpipes.
REAR END
-3.73 Gears
-Posi.
-Aluminum Differential Cover with Carrier Bearing Supports.
INTERIOR
-Katzkin aftermarket leather interior with suede inserts (Dark Graphite)
-White face Gauge kit (glows blue at night)
-2 Autometer A-Pillar Gauges. Fuel Pressure and Vacuum.
-T-Tops
-Front side windows, and rear tinted.
-Embroidered Floor Mats
-2 covers
-Misc. Paperwork.
Call Mark at 952-215-9697
More pics availible
You will not find a cleaner Camaro. This car is very fast and very nice. Come take a look you will not be dissapointed.
Willing to trade up or down for Polaris RZR XP
Discussion Starter #2
Would also consider other trades. Let me know what you have.
Bump this to the top
Still lookin for a trade TTT
Im still looking for a trade, Had a few deals going but they all fell through. Lets try this again. TTT
1 - 5 of 5 Posts
