the pistons move together and the plugs fire every rotation. it's called wasted spark..
the engine runs as an even firing twin, meaning that the pistons move together but they alternate which one is on the compression stroke..
harley davidson engines run the same way, they are proud of the wasted spark as it gives their bikes that distictive harley sound.
the term t-bap and t-map are interchangable as far as the sensor goes.. if it's on the outside of the throttle blade it is a t-bap set up where the sensor only provides temprature and barometric pressure..
for the systems that use the t-map, the sensor is on the manifold side (feeling engine vacuum) in this case it provides a rudamentary method of giving the ecu an idea of what the air demand is..(it's a cheap and easy way to simulate a mass air flow sensor) vacuum drops so it knows that your throttles are open, high vaccum means their closed.. the term t-bap and t-map actually relate to how the ecu processes the signal from the sensor.
if your t-bap sensor is jacked up or disconnected the ecu uses a limp home value. i believe it is equivalant to 600ft and 62 degrees(if i remember right)
in rustys case he was at 3000 ft, if his t-bap was plugged it was reading 300ft (home altitude) if it was bad the value for the ecu was 600 ft in either case he was getting too much fuel at idle, which would answer the question of "i unplugged mine and nothing changed, how could that make his run bad)
also if the tbap was messed up it could have given a false reading of who knows what altitude..
altitude in the tbap is calculated by reading the drop voltage on the back side of the sensor, multiply that voltage by 25 and it gives you pressure in kpa. as an example, at 300 ft 60 degrees, the atmospheric pressure is roughly 105.6 kpa, at sea level the same temp the pressure is roughly 94.8 as you can see it only takes 1.11 volts to change what the ecu sees in elevation by 3000 feet, so any kind of contamination or manufacture defect, or power fluctuations can really screw up what this sensor is telling the ecu.
nothing like a good brain dump at 1:00 am
m²
