First Name: Chris
My RZR: xp 900
Member #41363
Well 1000 started acting funny so changed belt it has 800 miles old looked fine roller had flat spots still won't go over 60 with new belt any ideas
If the rollers had flat spots it's not shifting out all the way... Your spider jam nut could be loose too!!! Have you serviced the clutches before this problem???
Watch the tach on the dash to see if it the engine is developing RPM's. If it is getting up to the 8000 plus, I think, rpm range and you are only doing 60, belt clutch issues. If it is not making the rpm's then check air intake, new filter maybe.
