that looks crazy (in a good way)! how is that working for you?Junk-Yard Filter and box..W/ 3" plumbing...What good is its easy to check and clean.![]()
One more note: I have 2 filters in it....A primary and secondary..all in one Junk Yard Air box:rofl3::rofl3:Junk-Yard Filter and box..W/ 3" plumbing...What good is its easy to check and clean.![]()
What vehicle did you get your junkyard filter housing from Leo? I've been thinking about replacing the stock junk with an airbox from an XJ cherokee and installing it in the rear similar to yours but your airbox looks a bit more compact.Best one I have had so far Robert...Every-thing else sucked dust up here...
It came outa a pathfinder...With a 6-cylinder in it...when you install yours make sure to use 3" piping...I tried 2" piping and it restricts...I am going to run my fresh air intake up higher to get cleaner air...prolly mount it to back of cage...What vehicle did you get your junkyard filter housing from Leo? I've been thinking about replacing the stock junk with an airbox from an XJ cherokee and installing it in the rear similar to yours but your airbox looks a bit more compact.Best one I have had so far Robert...Every-thing else sucked dust up here...
Vince
..When you get-her done post up some Pics...I am going to do a write-up and review on Junk-Yard Air Box...In a few weeks...and another Junk-Yard air-box test would be good to go with review....Thanks Leo, I'll be hitting the local pick & pull later this week.
Vince
