1 - 5 of 5 Posts
I'm installing a blue sea fuse block I got the factory harness to bus bar under the hood and my winch is hooked to that, instead of running a 10awg from battery can I just run a short feed from batt lug on bus bar to my new fuse block? Or should I run a new wire from battery? Is it fine having 6awg from winch and factory harness on that lug then having a short 10awg to fuse block?
I think I have 10 or 12 gauge running from the buss bar to my fuse block. The run is only maybe 12 inches or so.
Ya thanks man I'm just going to run a 10awg from busbar with a 40amp breaker
Which fuse block did you get from Blue Sea?
1 - 5 of 5 Posts
