Wiring a dual mode LED light bar
1223 Views 14 Replies 6 Participants Last post by  21turbosjr
What’s up my polaris peeps! In need of your help in wiring up a dual mode led bar to rocker switch. It has outer amber lights and middle white lights. It came with a really cheap danky toggle switch. But that switch can power on the ambers only or whites only individually with their own toggle, or flip both on and run the whole bar at once.
The harness has 4 wires coming from the relay to the switch( black, blue, red & white ).
The led bar has black, red(white leds) & white wire(amber leds).
how can I wire the 4 wires from the harness to a 3 position 7 pin rocker switch to install on my dash ? The rocker switch function is ON-OFF-ON. I’d like for the ON(flipped down) to only power on ambers and ON(flipped up) to power on both ambers and white.
i’d be removing that connecter and adding female spade connectors for the rocker switch.
See less See more
5
1 - 15 of 15 Posts
you need an off-on-on switch to do what you want. It is possible to get that switch to do that, but it will be beyond your capabilities (you wouldn't need to ask if you had them) and you still need to purchase other items to do it so you might as well get the right switch instead.
Well that blows. & I can’t even find and off-on-on switch. I even tried looking on Baja’s website for their onyx 6 dual mode led bar and they sell their harnesses with little small individual toggle switches too. So Everyone with dual mode bars are either running the janky switch or run 2 toggle switches and drills their dash out to mount them? What other items were you referring to Besides relay, fuse, harness & switch ? Thanks
if it’s not doable then my last resort will be to just use a different same wattage harness and miss out on the dual function of the bar.
See less See more
Look here for switches etc.
  • Like
Reactions: 1
thanks for that site, they have a ton of things !! It’ll for sure come in handy.
but looks like they also don’t have off-on-on switches. Damn
See less See more
  • Like
Reactions: 1
I think what you want to do is achievable, but let me see if I have a switch laying around to confirm. Worst case all you need is a diode to isolate the white and blue wires on one side of the switch. I'll post back with a diagram once I've confirmed.
  • Like
Reactions: 2
If Terminals 1/2/3 are isolated from 4/5/6, this should work. Otherwise, you'd need a diode like FTM mentioned.
EDIT: Note, the power wire would need to come from ignition/accessory power if there's an LED for the "off" position. If there's not, you can use the power wire in the harness. I don't know.
See less See more
  • Like
Reactions: 3
  • Like
Reactions: 2
Beat me to it!!! And a better drawing to boot! Lol
I checked a few of my switches, they are both isolated circuits left to right. So this is doable. All you need to do is pick whether the white or blue wire goes by itself, and top or bottom based on how you want it to function. We don't know if white is amber lights or white lights, that's on you lol.
  • Like
Reactions: 3
Nice!!!! Hell yeah! Appreciate you guys !
how can I test the switch I have that’s on off on if they’re isolated? Should be right since all on-off-on serve the same function? That looks pretty straight forward.
So directly from the bar wire it’s red wire for whites and white wire for ambers but from the relay to switchI’d have to try both to see which way lights it up the way I’d like it too. On one circuit ambers only (flipped down/on) and then one circuit all lights (flipped up/on).
yeah so for the power wire I’ll not be using the one from the harness as I want the led to be lit with keyed/acc power.
hell yeah guys!! I’ll post back on my findings
  • Like
Reactions: 1
To test the switch you need a multimeter, set to ohms(resistance). Put one probe on the left terminal and one probe on the right terminal that is next to it. You should see OL on the display. If you read a value like 2 ohms, it will not work. Any cheap multimeter will do, you can get one at Walmart, auto stores, etc.
Findings?
Sorry guys haven’t been able to update this thread. I actually ended going with a switch panel just haven’t installed it yet. Running a switch panel can clean up some of the wiring under the hood. Will be wiring the outer amber Leds to my current amber pods on the pillars to come on together. Will update with pics when I get it done!
1 - 15 of 15 Posts
