1 - 3 of 3 Posts
hey i just got my rzr put back together and tried everything out and it all works except for my winch. does the accessory fuse run the winch? reason im asking is b/c i checked the fuses and the accessory fuse was burned up. so i put a fresh one in there and now its burned up. Any ideas? thanks in advance.
You mentioned you put it back together, what did you take apart is probably the question. If its related retrace your steps regarding the electrical wires. If not then reroute the winch to the battery and use a separate fuse. I believe you can take power from under the dash. Hope this helps.
the accessory link just provides a 12v signal to allow the solenoid to close, power is drawn stright from the battery/charging system
are you sure there arent any shorts/crimped wires/etc? maybe a power wired got crimped while putting everything back together
1 - 3 of 3 Posts
