Will not start!
24K views 18 replies 11 participants last post by  Larry leisse
I have 2019 S (4 seater) will not start, battery full, break pedal pressed. We popped starter few times with 3/8 extension and hammer, started. Next day no start😒. Starter? Solenoid ? Thanks
Not sure what popped starter means.....For most of these types of issues I will see if you're getting power to the starter, solenoid during cranking. If so and all the connections are tight then most likely the starter...if nothing at the starter (crank circuit) then check all the fuses. I'm not familiar with the fuse box or the wiring yet on these things..Sounds silly but make sure the hot and gound are tight at the battery....
Supongamos, hasta que nos digas algo útil, que realmente quieres decir "no arrancaré". Lo que obviamente es bastante diferente a "no arranca". La implicación habitual de golpear un motor de arranque con un martillo (supongo, una vez más, eso es lo que significa "Popping") y tener un resultado positivo es algo así como malos cepillos, un punto plano en la armadura, etc. Si es así, es tan simple como mirar en un voltímetro y ver si el motor de arranque está recibiendo voltaje al girar la llave. Si no, bueno, entonces es un problema de cableado o relé y uno rastrea el camino.
  • Like
Reactions: LinkedXJ
Suppose, until you tell us something useful, that you really mean "I won't start." Which is obviously quite different from "won't start". The usual implication of hitting a starter with a hammer (I guess once again, that's what "Popping" means) and having a positive result is something like bad brushes, a flat spot on the armature, etc. If so, it's as simple as looking into a voltmeter and seeing if the starter is getting voltage when you turn the key. If not, well then it's a wiring or relay problem and one traces the path..
Just passing along the same info I received! If anyone is in this situation out on the trail, or like me trying to load my machine into the trailer! Turn the key as though you are starting then press on the brake pedal and it should turn over. At least in my case it would. When I was troubleshooting, pressing the brake pedal, the brake lights would come on for a split second then go off.
[/QUOTE
Look under the driver side wheel well at master cylinder feel back behind master cylinder unplug that little 2 wire plug use Paperclip or some kind of wire and cross jump just suffered the same problem last weekend
