1 - 4 of 4 Posts
Need an answer pronto !! I have a chance to buy a 2011 Sportsman 800 engine, but I want to make sure it will work in my 2010 RZR. Everything looks identical on the engine, other than a black case on one side. Is there any thing that would be different or will it just go right in and fire up ????????
Well, I discovered the mounting points are the same except where the engine and tranny bolt together. I believe I can make a bracket that will work. The Sportsman engine doesnt have the mounting lugs in the lower case that mate to the tranny. Other than that everything looks identical. I bought the engine ! When I get it I`ll give an update.
Thanks for your input Papabare.
Trikerjon
Well I did it ! After 4 days of bustin butt I got the Sportsman in and fired it up today. It was not a job I would recommend or do again. I had to make a mounting bracket twice, because the first one dis`nt work. With a lot of cussin and perciverance I finally got everything lined up and it worked. My advice.....don`t do it if you are thinking about it.
1 - 4 of 4 Posts
