Has anyone found an aftermarket E-brake for the RZR? I am so used to parking my fourwheeler anywhere. I keep getting stuck in Park parking my RZR on hills. It's driving me nuts. I'm thinking of building my own.
guy48065 said:Gather all the necessary supplies:
* Manual line lock.
* 24" braided high pressure hose. If a suitable 1/8" brakeline with 90 degree inverted flare fittings can't be located you may have better luck finding a similar hose with AN type fittings.
* Adapters are needed with AN fittings to mount line lock to inverted flare stock brake line & distribution block.
I began the project by adjusting a laser crosshair to fall on the top/center of the rear of the console. Then I removed the console, seats and engine access door. The brake system rear distribution block is now visible.
With the laser still on I cut a strip of 1/8” aluminum to fit under the console (7” in length) and centered it on the beam. The line lock is held temporarily in place with carpet tape while the console is replaced & tested for interference.
Mount the valve as low as possible so the hydraulic lines won’t come into contact with the console or shifter bracket. The valve shaft can be extended with a coupler and piece of threaded rod. Once all clearances are verified, drill & permanently mount the valve & bracket.
Reposition the laser so it’s centered on the valve shaft. Remove the shaft extension and remount the console. The laser will mark the location where the hole is to be drilled.
Reinstall the shaft extension. Check to make sure brake lines will not contact driveshaft. Reinstall the console, shaft knob, shifter knob.
Done.
To operate: Depress the brake pedal. Push down on park lock knob. Release brake pedal. Brake pressure is held in rear brake lines. Brake light will also be ON when ignition is on due to line pressure activating the brakelight switch.
To release: Depress brake pedal. Pull up on knob.
Some sort of indicator is planned to show when the lock is engaged. Don't want to put on too many miles with the rear brakes dragging []
guys, check out the pawltector. Rxutv sells them. I just installed one and it works great. 15 minute install and $85!
Engaged:
released:
