Think we figgured out what was wrong today. One header cracking is odd, two cracking says that something else is wrong causing it... The cracked header pipe is the symptom, not the cause.
One possibility was that it was running lean which was causing excessive heat to be generated but they checked and said it was almost right on spot. Another was that something in the hanging system was outta whack and someone here sent me a pic of his that did it twice showing where the hangers for the muffler were welded with one cocked off at an angle, about 1/2" inch out of aligniment which was enough to cause a binding in the spring hangar system which prevents stress from being transferred forward to the header pipes.
After the system check the dealer pulled the bed and sure enough one of my hangars was almost 3/4" of an inch off the mark... You can even SEE the indent made in the subframe rail where it was SUPPOSED to sit into while being welded and some welder at the factory missed the dam thing by 3/4" of an inch. The dealer manually bent the hangar back as a temporary fix so I could use it this weekend and had the small crack in my header welded up by an actual muffler shop. Deciding not to put the new header assembly on until they could order me in a whole new subframe assemnbly which should be in next week. Yes, it could have just been cut off and re-welded too but this is nicer of them, just replace the whole piece.
The welding shop actually said it was a very minor crack and man they did a sweet job of welding it, they finished it, sanded it a little, and then coated it inside and out with ceramic header paint and by the time I got home you couldn't tell anything had ever happend. Sweet. They said that as long as the stress has been relieved there is no reason I couldn't keep using that header forever. But hey, Polaris is doing it all udner warranty and new is better for everything. After all, this is some slug at the factories screw up.
