WHICH SPRINGS
1 reading
4.6K views 19 replies 8 participants last post by  Travo
As bad as I hate to im gonna have to put tenders or a spring kit...these machines sux for ground clearance it has me almost wishing i would have stuck with my 18 dynamix...let me know what ya recommend id like 2 inches of ground clearance and plush ride
I talked to Polaris about this problem and was told they do know about it and hope to have a solution coming out mid to late June. It will be a free fix. I didn't want to wait so I went with Shock Therapy springs. I got back my ride height and I like having a true duel rate set up.
I talked to Polaris about this problem and was told they do know about it and hope to have a solution coming out mid to late June. It will be a free fix. I didn't want to wait so I went with Shock Therapy springs. I got back my ride height and I like having a true duel rate set up. View attachment 651689
I did the same with mine. But I believe Shock Therapy sent me the wrong springs. I had to set my pre load in the rear to 6 1/4” and 3 1/2” in the front. Both upper and lower springs in the rear are the same number. Was the the set up they sent you?
I do my measurement the same place that Shock Therapy shows in their install video. Any time I jack up my machine after I lower back to the ground I turn on my key to get the ride height back down to semi normal. You still need to move the ride a little to get it back to normal ride height.
#15 ·
I just received a call from Polaris regarding ride height and spring issues. Was told they have had a lot of calls and emails regarding concerns on sagging and spring issues. Told me there is a fix in the works and should be available in the next couple of weeks. Mentioned a possible stiffer tender spring but that’s all he would tell me. I asked him if it was ok to crank up my ride height he said to wait for the fix. We will see if this actually happens.
