WHICH HEADER IS THE BEST? Pro R engine testing of all headers on our Superflow 902s all brands. I will be updating this thread with more as I test.
8.1K views 21 replies 9 participants last post by  Joey Strub Bmp
Make sure to subscribe to this thread and comment if you like this testing or if you do not let us know what you think we should do different.
Tests are 3 runs with given set up then averaged.
We are not here to bash any company we are just showing our testing of products.
Pro R Dyno reading are slightly higher than our testing in the summer since it is 40 degrees in the Dyno room we do you standard correction but are about 5hp higher than summer.
All stock engine will only rev limit in ECU extended for Dyno purposes.
All stock engine with EVO header / Stock Muffler and only rev limit in ECU extended for Dyno purposes.
All stock engine with EVO header / EVO Muffler and only rev limit in ECU extended for Dyno purposes.
All stock engine with EVO header / EVO Muffler / EVO Tune with rev limit in EVO tune extended for Dyno purposes tune limit is 9000 so we do runs right to 9000 rpm.
All stock engine with RPM header / stock muffler only rev limit extended in ECU for dynoing.
All stock engine with AA header / stock muffler only rev limit extended in ECU for dynoing.
All stock engine with RPM header / 3 INCH muffler only rev limit extended in ECU for dynoing.
All stock engine with AA header / 3 INCH muffler only rev limit extended in ECU for dynoing.
All stock engine with stock header and 3 INCH muffler will only rev limit in ECU extended for Dyno purposes.
WHICH HEADER IS BEST? I SHOW YOU IN A POLARIS RZR PRO R FULL HEADER COMPARISON
WHICH HEADER IS BEST? I SHOW YOU IN A POLARIS RZR PRO R FULL HEADER COMPARISON WITH 3 INCH MUFFLER
Updated a few more!
Updated with rpm header
Updated with AA header
  • Like
Reactions: flying fish
Updated with 3" muffler and various header combos
Looks like the stock header with a free flowing muffler would be the way to go for trail riding...and the RPM header and free flowing muffler would be good for WFO dune riding.
I that what you guys are seeing?
Chris
I think you pretty much nailed it!!
Looks like I'll be leaving the stock header on and probably doing the RPM muffler.
We do make a pretty nice muffler that is not ear piercing and has a nice throaty tone too.
Will there be a muffler comparison with the stock header? A lot more mufflers out there than headers. If you do please put a db meter in the room. Even if its just a cell phone app. I know it wont correspond to outdoor sound levels but it should at least give a comparison one vs another.
Yes I did a muffler comparison for Free flowing 3", stock and evol
#20 ·
Great information and good to see how the various brands of headers stack up - Polaris OEM being pretty impressive. Seems a 3" flow through muffler on OEM headers with a tune, is the best value proposition - then add Bikeman cams and you have an amazing package, with a big power improvement for $3k. Keep the $100 per hp coming Joey! Typically when dealing with NA motors, that formula ($100/hp) is not going to work.
Looking forward to adding more power this summer.
#21 · (Edited)
Fantastic information Joey! Just what I was looking for. Really appreciate the unbiased testing and hard numbers in an apples-to-apples environment. Question, that lag on the bottom end with the aftermarket headers, can that be tuned out or is it just the way it is with the flow of the header? It seems the bigger the gain on the top end, the bigger the dip on the low end.
#22 ·
A well made header will make about the same power but by changing the primary tube length you can shift the rpm efficiency window around.
  • Like
Reactions: petedog
