1 - 10 of 10 Posts
Hi guys,
My buddy just blew the motor in his 2012 rzr S. He says there is a hole in the case above the oil filter.
He is interested in replacing it with something better. Who sells Weber motors?
Thanks for the input.
If I understand correctly the import of new Weber crate motors, at least the "drop in" motor used in a conversion, is being blocked because of DEQ restrictions.
The weber motors are awesome and not too bad to install but you could search out for a used Z1 sled or apex and put out way more power bone stock. The install is alot harder but if you are looking for a motor swap why not go bigger? Dont get me wrong I like my weber and its great because it is very trail capable and enough power where I turn down the boost most of the time :). I even rock crawl with it.
If you are set on the weber try to give Mark Queen @ queen racing. He is the most knowledgable on the webers. He may have one too.
WeberPower in WA is pretty good to deal with. I got parts for my Redline through them. You can also look around for an Ultralight shop. as this is really popular with that crowd.
I own a f1100 with a turbo dynamics tune. I trail ride at nearly 260hp on pump fuel....can't even imagine how much fun that would be in a rzr!!
Hi guys,
Webers are in the POLARIS FST's (Four Stroke Turbo) snowmobiles
There's a LOT of BRAND NEW 2011 +/- POLARIS FST's snowmobiles left sitting at the POLARIS dealers.
Approx $8,400 for the entire sled. Check e-bay, google it, etc.
Sell off the parts you don't need, and you're into a BRAND NEW engine with primary clutch, wiring fuel system etc for $ 6,000 +/-
Hi guys,
Check with Mark @ Queen racing...
1 - 10 of 10 Posts
