1 - 13 of 13 Posts
I dont like the spun aluminum ones. what something that looks nice, gives a little better off road ability but doesnt hurt performance too much.
Also, are the lift kits worth it? they seem pricey.
Craigslist my friend. I have 2-170's. got these Itp aluminum rims for my girls ride with 24" maxxis tires for $260 total. The ground clearance is amazing compared to stock. I would recommend getting the 11 tooth front sprocket to help with acceleration.
For my sons 170 I bought a set of 24" dirt devil tires mounted on Honda rancher rims with 1.5" spacers. They are beast on his ride. I don't have photos on my phone if his but I will post upon return from vacation.
Jeff
It order it all separately and installed at home. Save about $100 and used it to upgrade front and rear shocks. I think the tires are 23x7 on all 4. With a 2+5 offset on all 2 wheels. Dropped for a 12tooth to a 12tooth sprocket so I won't lose power. Front shocks are raptor 660 fronts and rears are z400 fronts
Sent from my SAMSUNG-SM-G900A using Tapatalk
So I’ve been scrolling and scrolling, but sometimes certain posts seem to lack a bit of info.
Plain and simple, on factory wheels, whats the largest tires that will fit the 170??
I got a quote for 22x10 for the rear and 21x9 for the front. $250cdn . Don’t know if if I can go bigger??
Did you ever get a answer?
Thanks
Jeff
Hi Jeff,
How have the 24" tires worked out regarding any rubbing and do you have any lift?
Are the spacers 1.5" all around ?
Thanks,
Joe
Hi Gotbrute,
I have info on here where people are going as high as 24" front and 25" in the back, there is however a lift and spacers needed. I'm looking to put 23" tires on my son's 2016 rzr 170, just would like to have a lift and that's is not easy in Canada. Any good welders make up a good set I was hoping. No luck yet for me.
How did the 23x8 tires all around work out ? They all have the same offset as well, I thought that the 2+5 offset would be a problem on the rear.
Thanks, Joe
1 - 13 of 13 Posts
