1 - 2 of 2 Posts
Vandal
The bolt pattern is the same but the ranger wheels use the larger 10mm wheel studs. If you use them on your studs they probably will fit very loosely causing possible wheel wobble and possibly cause your lugs to loosen
1 - 2 of 2 Posts
