1 - 10 of 10 Posts
· Cummins+RZR=<3
Hey everyone, I've been reading a lot about lifts, tires, and offset/spacers and have narrowed it down to something I think will work (probably a mod list I will be putting on in the spring time.) I was just wondering if I would have any clearance (or opinionated aesthetic issues:popcorn:) with this combo:
In a 12" model
Wrapped in these:
In a 26-10-12 front and 26-12-12 rear.
All of which would be under a racer tech 2" lift.
On a side note: If I wait till tax return time in the spring I wold probably do wheels/tires/lift along with a wide band a/f ratio gauge, a looney tune exhaust, some sort of tuner, and a bike mans adjustable clutching system.
I really am interested if the wheel and tire sizes are going to clear the lift (or maybe be to small?), but would like some opinions on the brand/size of everything I mentioned.
Thanks everyone!
· Registered
From what I have read you will rub your motor mount with that combo. Maybe 10's all the way around would work. Swamp Lites are supposed to grab everything but wear quickly. If you want to run that combo spacers in the rear will probably be needed. Good luck!
· Registered
I've tried 28X10X12 swamplites on my standard RZR and they rubbed on the front swaybar without 1.5" spacers. They actually fit on rear (barely) without rubbing the motor mount and this was without spacers. They were all mounted on 4:3 off set rims and I have a 2 inch lift.
· Registered
Is width going to be an issue? I suggest wide offset wheels if its not...just a suggestion.
· Cummins+RZR=<3
Discussion Starter · #7 ·
Sounds like your mounting a sneak attack with all those mods.
I can't wait to see the look on you guy's faces when I pull in your Driveway with a Monster RZR haha. I got billed for the springs finally so hopefully I will have them on for when I am up in Punxsy next weekend.
The wheels I have pictured there are a different offset than stock. I think they will push the wheel out about 2" if I am not mistaken. Can anyone confirm that?
· Registered
my 26x11x12's on 4+3 offset were about 54 to 54.5 in the rear so yeah 2 inches is about right. I was talking about something like the 5+3 or 5+2 (cant remember which ones they are) offset wheels just to avoid spacers but the 312's looks mighty nice!
· Registered
I read that the 26" Swamp Lites are actually smaller than the stock 25's.
I have 27 x 12-12 and 27 x 9-12 Swamp Lites on ITP SS 212 (4+3 offset) and a Racer Tech 2" lift with no spacers and no rubbing at all. Perfect setup for the tight trails I run.
Thats on a STD RZR.
Vince
· Registered
Rings similar to where I am at. I have ITP XTR's 26x11x12 on the rear and 26x9x12 on the front. The front rubbed, and as I intend to put a 2" (or 3") lift in next week, I went with 2" spacers in the rear and 1.5" in the front (Super ATV). All works good, but did notice a bit of a loss in power once the ITP's were on it.
1 - 10 of 10 Posts
