1 - 20 of 219 Posts
Tuning off road suspension on a daily basis allows us to drive many vehicles with many set ups and different environments. UTV’s, sand cars, super lite, Pro 4 and Trophy Truck are just a few. So it may be safe to say that we have not quite seen it all but surely we are pretty close. With the increase in UTV traffic at the shop there is one thing that we see a lot that is a serious issue people should know about. Wheel offset and tire height.
One of the first accessories that people purchase for their new RZR or any UTV for that matter are wheels and tires. Better traction, taller tire, better ride, cooler wheels and wider wheels are just some of the reasons which are all good. But, if you choose the wrong wheel offset for the tire height you will get some serious negative issues that most people are not prepared for. Put simply, if the wheel is too wide or the wheel offset places the tire wider by too much, it will negatively affect the front suspension geometry and cause problems. Some of these issues are:
Excessive feed back into the steering wheel
Steering tracking with any line in the road or trail, wandering
Stiff steering feel, slow to respond
Overall stiff, rough ride over all obstacles
Premature wear on all front end and steering parts
How does this happen? Too much “scrub radius” in the front end geometry caused by wheel offset. What is “scrub radius”? Stand in front of your front tire and imagine a line running through the upper and lower ball joints of the spindle that continues to the ground. This imaginary line is called “king pin inclination”. This is also the line that your wheel and tire pivot on when you turn the wheel. Now imagine a line running through the centerline of the tire from top to bottom where the tire contacts the road. The distance between where these two lines where they contact the road is called “Scrub Radius”. We have made some CAD drawings of this to illustrate what we are talking about. These drawings show the 4130 boxed arms and spindle system on the Jagged X, SCORE and BITD car. This is a completely STOCK geometry system! In the first drawing we have a stock 5/1 wheel offset with a 28” tall tire. The scrub radius is shown at the bottom at .427”. This means there is less than half an inch between the king pin inclination line and the tire center line where the tire contacts the road.
The smaller the scrub radius is the less feedback to the wheel you get. The larger the scrub radius is the more feedback and shock load you get. Some road feel in the steering wheel is a good thing. This can let your hands tell your mind what the car is doing. Too much scrub radius causes all of the problems I listed in the beginning.
How much scrub radius is just right and how much is too much? This is pretty tough to answer because every form of motorsport requires different amounts for each intended use. For instance, road racing, go carts or even the new Vette off the dealer lot use a lot of scrub. As much as 1.5” to 2.0”. This is fine if you don’t hit any rocks. Smooth road courses and lots of power steering and less than 3” of wheel travel can cover up the negatives and allow you to turn a bit better and feel more in this situation. But, off road is a completely different animal. The last thing you want to do is feel a 6” rock or 10” ledge or 2 foot tall whoop every time you hit it and worry about losing a thumb to the steering wheel in the process. Additionally, taller, heavier wheels and tires used in off road for strength and for better ride quality place way more stress on the front end components and that stress needs to be managed. Too much scrub radius magnifies this stress exponentially. As the tire height and weight goes up, the scrub must go down. Industry norms are as follows:
Sand cars 1/2 to 1” of scrub radius
Class 1 off road, 1/2 to 3/4” of scrub radius
Trophy Truck 1/4 to1/2” of scrub radius
Only two three things can change scrub radius. One, spindle design which also means new upper and lower arm design. Since most people are not going to design a whole new front end for their RZR, this option really isn’t an option.
Two, wheel offset. The wider the wheel is the more scrub radius you can get. More importantly, the more wheel offset you get (less to the inside and more to the outside) the more scrub radius you get. Stock RZR 1000 front wheels are 5” inside and 1” outside. This is measured from the hub mounting flange or where the wheel bolts to the car. A 4/3 wheel has 4” inside and 3” of wheel outside of the hub flange.
Three, tire height. The taller the tire gets on a given front end and wheel offset the less scrub radius you get because the two lines (tire center line and king pin inclination) have a longer distance to intersect as the tire gets taller. The CAD drawing below shows a stock wheel at 5/1 with a 30” tire on it. The scrub radius has gone down from .427” with a stock tire to .343” with a 30” tire. This set up would be very smooth feeling. It would have a very low stress level on the front end parts and would never add to a rough ride. Road feel is less but by such a small amount it would be hard to notice.
This brings up the question “what is the right amount of scrub radius for a UTV”? The answer is purely subjective and open to debate but if you want our opinion we would say that no less than 1/4” and no more than 1”. The reason we say this is because the wheel and tire package on most UTV’s are comparably lite. Between 28lbs and 65lbs and not that tall. The loads developed by these are way under a Class 10, Class 1 or Trophy Truck. You can get away with a little more scrub (1”) than these other cars can. We can also say this because we have driven UTV’s with scrub numbers in this range and we would say anything in this range is fine. Just remember that 1” of scrub radius has more road feel in the wheel and more force applied to the front end. 1/4” of scrub has less of both but may not have enough road feel for some people. Factory is just under 1/2” at .427.
Now let’s take a look at how bad the scrub can be with some of the popular wheel and tire combinations out there. Below is a CAD drawing of a 4/3 offset wheel with a 30” tire. It has a 1.843” scrub radius! Wow that is a lot. This is the wheel and tire combination that we see the most problems with.
Customers complain of rough ride, wandering steering, arm pump and worn out front ends. A lot of people bring their cars to us hoping that our suspension kits will fix their issues not knowing that it isn’t the suspension’s fault. But, sadly the answer is no, out kits won’t fix their geometry problems. The suspension will work better and feel smoother but the underlying issue is still there and will continue to create problems.
Some of you may already have a 4/3 offset or more and wonder if going taller with the tire will help you. The answer is yes, but, not nearly enough. If you jump up to a 32” tall tire you will only lose .083 of an inch of scrub. The scrub radius only dropped down to 1.760”. Still way too much. As a matter of fact, you would have to run about a 50” tall tire to get it under an inch of scrub and all the way up to a 63” tall tire to get it back to stock scrub radius. The drawing below shows a 63” tall tire and .423” of scrub radius. Ridiculous I know.
Here are some combinations that work just fine and drive great. Below is a 28” tall tire (stock) on a 5/2 wheel. .927” of scrub. This is pushing it a bit close to the 1” max but this ok.
This is a 30” tire on a 5/2 wheel. This has .843” of scrub. Better than the stock tire and well within the “happy” range.
This one shows a 32” tire on a 5/2 wheel. It has .760” scrub. Very good combination. Clearly you would be just fine with any of these.
You may wonder why, the wheel company’s offer a 4/3 or even bigger offset wheel if there are so many issues with it. After all, they should know all about scrub radius right? Well, the reason we have heard from some in the industry is that the 4/3 offset was perfect for the RZR 900 front spindle. When the 1000 came out with a wider axle length in order to get more travel, the extra width went into the spindle design and into the wheel offset of 5/1. Since the wheel companies already had the molds and tooling for the 4/3 offset they continued to sell them while they developed a 5/1 or 5/2 offset. Good or bad, that was it.
In conclusion, the reason we have listed all this information is to help inform and educate. Because if you know why something acts the way it does you can make better decisions and more informed purchases. Any wheel and tire combo will work and drive. Just understand the difference in drive ability and longevity that come with those choices no matter which way you go. We hope this helps. Shock Therapy 623-217-4959
Larger pics here: Wheel Offset and Suspension Performance | Welcome | ShockTherapyst.com
what offset would you recommend for the 900s? sand dunes with paddles. want to take full advantage of my new suspension!!!
That's a trade off there....
Wide wheels will hurt your suspension performance but help you with flotation. Given we don't have a ton of HP to work with I am going to choose a wide wheels and flotation over a more proper rim and suspension performance. They stated somewhere in this thread that at the dunes you get away with running a a wide wheel and there wouldn't be a whole lot of negative effects until you get in the whoops.
I have 4+4 rims with ribbed fronts, sandslingers on rear, and im super loose. to the point its freaky sometimes. not sure if its the ribbed fronts, the short wheelbase or what is causing it.
ive messed with air pressure too, which seems to help a tiny bit.
When you say super loose, you mean from wheel spin or the front end won't stay planted? Or both?
How much air are you running normally?
Seems to go wherever it wants at times. 6lbs in front
Discussion Starter #9
As mentioned, you can get away with more offset in the dunes because there are not rocks or sharp corners to really kill the front end. But, there is always a but. The farther you push the offset out, both wider over all and tire center line by moving the inside of the wheel out (offset) you will get a more stable car from a floatation, tip over, sit on the side of dune type of feel. It will also turn quicker because the wheel offset and scrub radius wants to follow any change in the trail or input from you. BUT, the quicker turning feel also wants to track anywhere it wants when your going straight. This gives you the loose feeling because, essentially with all that scrub it wants to always turn and resist going straight. Great when you want to turn, not so good when you want to go straight. The front ribs are not causing the problem. Since they have turning traction, they are just showing you what your wheel offset wants the steering to do. Turn, not go straight.
So what would I recommend? Tough one. I think it is a personal preference thing. I like the car to do what I want it to when I want it to. I don't like it to turn for me when I hit a sand car track. I also don't think the extra floatation or body roll stability is worth it. I would rather run the sway bar stiffer and keep the tires in a bit. Same thing as widening the tires and keeping the sway bar loose. But, there are tones of guys who will swear by the extra width and love the twitchy steering feel. Neither are wrong. To each his own. So, don't take my opinion as the bible, just ask around and drive different set ups if you can. See what you like.
Discussion Starter #10
Less pressure is great for floatation but if it bottoms out a lot in the g outs even with the compression knob turned stiff you need to run more pressure. We have tested with video G outs. Pressure is a big deal. With it low and you hit a g out the sidewall of the tire compresses to the point that the wheel touches the sand. This just blew through all your ground clearance. You can drag the skid plate and still have an inch or two of shock shaft showing because you never used all the suspension, just the tire in the bottom out. So, if you find this happening to you then raise the tire pressure 2 lbs at a time and start over on your compression knob adjustments. You will find a happy place where your pressure is 8 psi and you have 20 clicks in the compression or maybe 10 psi and 10 clicks in compression. Again, personal preference just be aware of it.
Maybe try a 7" wide 4+3 wheel? That still isn't ideal but it would get you a little closer and negate the effects a little bit. Might be enough?
Electrical Contractor
I will be sending in my shocks very soon. I think I will be doing your stage 4 setup. I also want to get new rims and tires. I just want to make sure these will work with your setup. I want to get a 15" rim with a 4"x7" offset. I also will be buying the motto hammer 30x10x15 tires. Just wondering if this will work with what you explained in this post?
Thanx
Discussion Starter #14
Thanx
Looking at your picture do you have a 900 or 1000. Big difference in wheel requirements.
I have a 2015 XP4 1000
Discussion Starter #16
Ok. If you thinking of a 4/7 offset that would be an 11 inch wheel. Is this correct? Also, are you talking about wheels for your offroad tires or sand tires? Here is why, if your talking about the rear wheel only for a sand tire then your fine. But if you put a 11" wheel with a 4/7 offset on the front you couldn't get any worse than that. That would be the exact thing the above article is trying to point out not to do.
The rims and tires I am talking about are for dirt use. Trail riding.
Awesome. Thank you. I will be contacting you shortly about sending in my suspension for some your your magic. Thanx again. I really appreciate your help.
Awesome info, as you stated most people including myself already have wheels/tires.
I bought 14x7" (3.5/3.5 offset) wheels with Mongrel tires 28x10. This is on a 2015 900 4 seater. I'm now sitting over 64" wide so hoping this didn't throw me off as much as 1k's. Any idea where I sit on my machine?
Also, can't wait to get some ST treatment on my setup.
1 - 20 of 219 Posts
