1 - 3 of 3 Posts
While I was riding last weekend i felt a wobble in the rear. I got off and checked the wheels and i was down to two lug nuts on the passenger side.....and one stud is broken and loose. I finally got the lug off this morning and i'm wondering if i need to change the hub and bearing. If I decide to replace one then i'll want to replace the other. I'm looking for recommendations on where to buy the parts. I need hubs and bearings.
If you are interested in upgrading to steel hubs instead of sticking with the aluminum rear hubs this post should give you all the info you will need. I personally did this upgrade and have not had anymore hub problems since. As for bearings I've had the best luck with oem bearings.
1 - 3 of 3 Posts
