21 - 26 of 26 Posts
Used my new Havoc wheel bearing greaser today and it worked great. Each bearing took at least 10 pump's and one took 16.
Easy job and we'll worth the effort.
I could only find 2 other zerks to grease while I was at it both on the drive line thru holes in the skid plate.
Does anyone know of anything else to grease and were.
Mine has two zert fittings on the rear sway bar bushings
Yes. I ended up having a buddy machine the center out to 1.225 today. I will see if it works tomorrow.
I bored the tiger tool for my xpt out to 1.225" and while it worked on the pxp it did get into the threads for the zerk on the tool so I have a little leakage. I didn't measure the spline diameter when I greased the bearings but I would try 1.2" if I did it again and see if it works because I have plenty of clearance between the tool and splines now.
what are you using to bore it out to that? just a drill press or something much more precise for the 1.2
We have ours available. In stock. MADE IN AMERICA!
Shown here that it does indeed fit the Pro XP:
http://instagr.am/p/B-KjTmDpEQm/
UTV INC Polaris Sealed Wheel Bearing Greasing Tool! No need to remove the entire assembly to service them! Simply remove the axle nut & hub, slide the greasing tool over the axle and pump the bearings with grease! CNC made from billet aluminum, designed & manufactured in house at UTV INC in Mesa, Arizona. This tool will work on the front and rear wheel bearings for all the following models listed.
Fit's front and rear bearings on following 2014-2020 Polaris models.
Polaris XP 1000
Polaris XP4 1000
Polaris XP Turbo
Polaris XP4 Turbo
Polaris RZR 900
Polaris RZR S900
Polaris RZR S1000
Polaris RZR S4 1000
Polaris Trail
Polaris XP Turbo S
Polaris XP4 Turbo S
RS1
RZR PRO XP
RZR PRO XP4
21 - 26 of 26 Posts
