1 - 20 of 39 Posts
· The Beast
What about a small inline four turbo diesel? They are compact, simple and should have a lot of torque.
· King of crash!
a line has to be drawn someplace...if that much power is needed go a 2 seat hyabusa buggy or sand car... their is limits to what can be done with a rzr...a 2 seater hyabusa buggy is only about 14 k and alot faster at some point you cant have it all and need to decide what you want..a rock crawler...sand car..mud bogger..desart car... and go from their.
· Registered
Yea but it's just talk. Why you trying to ruin it........:rofl3:
· King of crash!
i know i had to ruin it...lol but i wonder why nobody has tryed to us gm's ecotec 2.2 yet its small
· Registered
Discussion Starter · #7 ·
Yea that would be a crazy engine. The torque of that engine is linear from the start all the way thru the RPM range. Add Nitrous and you get 250HP. Talk about a screamer... Thou I think it's too high to fit...
· Registered
There are a couple vtwin bike engine swaps out there.
Honda RC51 I think???
Sled engines like the Weber and Apex are a good choice if you want to keep the CVT.
I have seen a few RZRBusa builds announced and started,,, but haven't seen any info of one being finished and running...???
· Registered
Besides adding a Turbo or Apex or R1. Has anybody ever shoe-horned in a small V-8 or something? Just looking to see what would work or who has made something different to work....
I'm looking into an ARCTIC CAT Z-1 (SUZUKI) TURBO engine for a RZR swap. Comes in 2009 and Newer A/C Z-1 Turbo snowmobiles
It's only 2 cylinders, (NO frame stretch req'd) 1056 cc 4-stroke, liquid cooled, closed loop, with a factory Turbo, and a tapered crankshaft that will accommodate a ARCTIC CAT CVT clutch.
180 h.p.. STOCK,
E-Z 275 H.P. with a computer re-flash by Turbo-Dynamics, ON 91 OCTANE!!
315 H.P. with their water-methanol injection and a different re-flash
All DYNO #'s were just completed by DYNOTECH Jim, in New York this past week.
Back in the early 80's, I put a Big-Block Dodge into a short wheel base (91"-92") '72 Dodge Colt, it ran 9.40's @ 137+ M.P.H.
· Registered
Discussion Starter · #13 ·
180 h.p.. STOCK,
I thought that I read that they are having major problems with this engine right now... I could be wrong...
Either way, that would be one crazy engine to run in the RZR.
· Premium Member
I was told that the Z1 is just as wide as the APEX. I had thought it would be good to use too. But, got shot down on that. I do not have one to measure.
· Registered
Pix are on nelsonsspeedshop.com Parts fiche on line
Mounting is also more conventional, 2 studs straight down in the rear plus bracket up front
Siamese twin, not even close to the 4 cylinder APEX
I'm trying to upload a pic of that schematic, not having any luck, any ideas?
I have it copied as a "word" doc
· Registered
180 h.p.. STOCK,
Not true,
Check out hcs.com (HARDCORESLEDDER)
I've spoken to a few shops already on the reliability aspect and there are no issues.
If I'm going to go through the trouble of doing a swap, it seems to be a possible alternative to the WEBER.
It's a factory big bore version of a WEBER, at 1056 cc vs. 750cc. 180 h.p. vs. 130 h.p. STOCK vs stock
· Registered
Discussion Starter · #17 ·
± 6k plus man hours and you have a crazy turbo setup for the RZR...
Nice.
· Registered
I've said this a few times. Its hard to understand why people spend 30K-40k on a RZR for playing in the sand.. Seems like they would just be better off with a sand car.
That said I'm all for watching people blow their money! Why not a freaking Jet Turbine!
· Registered
Discussion Starter · #20 ·
Simple answer, it's different!!
1 - 20 of 39 Posts
