1 - 11 of 11 Posts
· Registered
A couple of weeks ago I bout myself a good waterproof grease i found. While I was doing my skidplates i saw that the drive shaft has a zert and calls for a different type of grease.
My question is does it really matter or can i use the same type of grease without any problems or doing any harm. thanks
· Registered
Who makes this new green grease? Is it green because environmentally friendly? Do you use this on all the zerts even on the driveshaft ujoint?
G
i use the new GREEN GREASE this stuff is the best ive ever found as to staying where you put it even thru water. polaris sells there purple grease in the small grease gun tubes and its good but not even close to the green grease IMO
+2....Been using it for a few years...stuff stays put well and is very water resistant..hard to even pressure wash it off when it gets on something. Get some on your hands and try washing it off...even using dawn it leaves a little residue...lol
BTW around here most auto parts stores sell it..Auto Zone ect..
· AKA: blinginvic
I was just introduced to "Castrol Blue". I have loaded up my zerks with it, put haven't put it to the test yet. Supposed to be a superior heavy duty grease that is made to withstand the extreme environment.
Castrol USA - Castrol Pyroplex Blue
· Registered
Yes, you can mix any of these greases with any other that may be in the joint at this time. It's not aircraft, and no grease in the wheel bearings, so NLGI 2 is the perfect fit for our RZR's. All of these parts flex at very slow rates, so to speak. If I am correct, when you grease the rear joint on the driveshaft, it is really only the spline area, and not the u-joint itself. Any type of grease is better than no grease at all. I shoot my machine once a week, as the wife runs through water on a very regular basis.
1 - 11 of 11 Posts
