What belt with clutch kit; Stock or EPI?
  • Stock oem
    Votes: 146 72.6%
  • EPI severe duty
    Votes: 55 27.4%
1 - 20 of 64 Posts
I have an 09 Rzr-S with DDP clutch kit and its time for a new belt! I want to know what everyone recommends!
Before the Weber I ran an EPI belt for nearly 1000 miles. Never had an issue. Still looks like more than 60% of belt life.
King of crash!
i have been using the epi.... but last one broke and i put a s belt on lasted as long but with a little more snappy response and more top speed well when the s belt broke i had a extra epi and put it on and again lost top speed and not as snappy.... swapping back to a s belt for thanksgiving will see then...
X2, went back to the stock belt and found the same thing. The original '08 belts were crap, but the new stock belts are fine, IMO.
Agree s-belt much more heavy duty than stock. Check belt threads I was turned on to a place back east bought 2 s-belts$ 190 delivered. Best $ in town $155 each after tax
I'm running with a EPI belt and stashed the factory 'S' belt in the tool box as a back-up if I brake down on the trail.
But after reading some of these comments I may swap the belts and use the EPI for back-up.
G
Stock belt...only time I would use an aftermarket belt is maybe as a spare. But I try to change my belts before they fail and keep an old belt for a spare. I've yet to see any evidence that ANY of the aftermarket belts are as good as a stock belt..
Stock belt only... I also use a new stock belt for a spare... I haven't seen any evidence that any of the aftermarket belts are as good or take the punishment the stock belt will take... I have the miles to prove it...
went stock, best part is there is a u tube video on how to put it on, I know have a spare belt and a 3/8 nut driver with me and I left out the 2 bottom bolts to hard to get to
2600 miles on our stock 2008 RZR with original belt!!! Getting ready to open the cover to check it out and clean the clutches.
Just kidding!
I have always run EPI belts until now. The last one blew into pieces after 2hrs Im going to run the S belt now and see how it holds up
Sent from my DROIDX using Tapatalk
OEM here
what are they going to do that you couldnt ,, clutch is basic once you take it apart you will see its not worth paying someone to work on it . bring in by my place and I will freshen it up for free or just bring your rzr by my house and we will do the work together will see what springs and weight you have and see if we can make it better ,
1 - 20 of 64 Posts
