What amps for a switch
2.7K views 8 replies 7 participants last post by  ZKCL04
I've been searching but can't find recommendations for the amps a battery cutoff switch should have. I have a couple off light bars and a winch, plus some low rates equipment. So need something in between all that and the battery.
Thoughts?
Thanks in advance.
Are you using a fuse block and switches on you accessories? If so, Use a relay and wire it to where your fuse block comes on with the ign. switch. If not, get a relay and fuse block big enough to hold all you accessories and wire it to where it comes on with the switch.
You don't need a battery shut off.
If you insist on a battery shut off.........
Google is your friend
https://www.google.com/#q=battery+shut+off+switch+amps
https://www.google.com/#q=battery+disconnect+switch+for+polaris+rzr
https://www.google.com/#q=battery+shut+off+switch+amps+for+polaris+rzr
There shouldn't be a minimum amount of amps, but there is a max amount of amps for a shutoff (disconnect) switch. 200a, 250a, 300a etc.
I hope this helped.
