When the key is in the on position it doesn’t do anything crazy. The minute the Rzr turns on the dash starts to go in and out. Sometimes it even stalls out or won’t start. I tried to use a volt meter to see if the battery is good and it says it is. All grounds are good. Could the ignition switch be causing the issue?
