1 - 11 of 11 Posts
Hey guys. So I bought an Amazon washer fluid tank. Looking for a place to mount it. I don’t have the space on the firewall between the frame, won’t fit there for some reason. Might be all the wires to my fuse block. What’s another place to mount it?
645230
645231
Standard Vendor
How about inside the cab on the fire wall. Should be easy enough to route the wiring and tubing through the wiring boot. Might even find some mounting bosses on the wall that you could use.
hmmm, that’s an idea. I could leave enough slack wire and tubing to be able to remove it to fill it.
Yes I realize that. I was just letting you know where the oem tank mounts in case you weren’t aware. Hard to tell how big your tank is and if it would fit in the same spot.
Discussion Starter #7
Gotcha. No it’s a thicker tank doesn’t fit down there
1 - 11 of 11 Posts
