1 - 16 of 16 Posts
· ◄►STARS & STRIPES◄►
I just peeled them off slowly from the corners..If you have any residual "sticky" just pick up some Goo Gone.. or you could try a heat gun/ Blow dryer..might help..
Nice user name:ride:
I used a heat gun and carefully heated the underside of the plastic, the decals peeled right off in one piece.
Vince
Ha, I beat you by 2 seconds!!:rofl3:
· Registered
i too just peeled mine slowly.i hate those stickers,my dads le 800 sportsman and my moms little polaris still have them,i aint messing with them.:p
i will probably invest in a dont screw with my rzr sticker though.:p
· Registered
?? lo0ol i use silly Trick
is you use alcohol lo0ol after you take the Stickers off use small amount and it is usefull but use pice of Cloth to clean it.
if Geting Alcohol problem for you like here ^_* here another Tip use any perfume you dont like 90% of perfumes got Alcohol Put plz Dont Drink them heheheheh
if you get Alcohol or you dont have any Cheap or unwanted perfume then you should try to remove it by rub with sand it will take long time but it works
· Registered
3M makes an adhesive remover/solvent that works great. Also a similar product called Acrysol works the same. These are available at any automotive paint store or at some common auto parts stores. This wont harm the paint either. One caveat---soak a rag in the solvent and place over the decal for several minutes then gently warm as mentioned with a HAIR DRYER (a heat gun may ignite the solvent..ask me how I know!!!). The decals will peel off and the solvent will completely remove the residue left from the adhesive. I have removed many a decal from race cars over the years (sponsors can change like the wind) and this worked best in my hands.
Also, Honda makes a spray cleaner/wax that works great to take out deep grime without harming graphics and the wax in the product produces a nice shine and makes cleaning easier next time.
my $0.02 Robin A.
1 - 16 of 16 Posts
