1 - 6 of 6 Posts
I hope someone can help.
I’ve read so many variations of nitrogen pressure for walker Evans shocks on a 2015 rzr1000 that I’m none the wiser.125 psi to 200psi what does everyone reccomend.
Also I’ve seen 5t and 10wt oil reccomended....which is correct .
Tia
Steve
Super Moderator
Do you have the shop manual?
per I call I had with a WER tech:
"use 10wt oil and 200 psi nitrogen."
however, after I talked to him a bit more and told him I ride east cost trails not dunes, he said I could lower the nitrogen pressure and be fine. so I run somewhere between 135 and 150 psi and I used maxima shock oil.
sorry this is 8 months late
1 - 6 of 6 Posts
