1 - 4 of 4 Posts
· Premium Member
Vivid Racing Presents: Agency Power OSB
Agency Power has just released its super convenient “Oh sh*t Bar” for the Polaris RZR. Not only does this part allow users a place to hold on for dear life, it also doubles as a functional tool. When you are in the dunes or out on the trails, you want to be prepared for whatever the wild throws at you. By integrating 17mm and 19mm sockets on either end of this bar, it doubles as a tool you can use in a pinch. This is perfect for removing wheels when out wheeling or tightening up loose bolts. Cerakote finish is available in 3 different colors to match your current color scheme.
Features:
Functional Grab Bar with Wheel Lug Wrench
Beautiful CNC Machined Components
Designed as an OEM Replacement
High Quality Durable Construction
Colorful Cerakote Finish
Made and Designed in the USA
Fitment:
2008-2011 RZR 800 and 900 (see notes)
2012+ Polaris RZR 800, 900, 1000, and Turbo
2013+ Polaris RZR 570
Notes:
2008-2011 RZR XP 900 and 800 can be used with the updated Polaris factory bushing, part number 5450705 (not included)
Will work with wheel lug key even on 10 inch wide wheels with a deep lip
MSRP: $295
View product on our site by clicking here
· Registered
Looks nice but a little pricey for myself, well made
· Premium Member
Discussion Starter · #4 ·
**END OF THE YEAR IS COMING TIME TO GET AS MUCH 2017 MILES IN AS YOU CAN**
Passenger grab bar with integrated wheel lug wrench is the ultimate accessory for your Polaris RZR. The grab bar, also known as the “OSB”, was designed to provide a high quality and stylish passenger grab bar that solved one of the biggest needs on any RZR. Most aftermarket wheel lug nuts use a wheel key adapter to remove the lugs which is usually a 17mm or 19mm socket. While riding the trails or the dunes, you will see tons of spare tires mounted on these side by sides, but you can bet they don’t have a lug wrench or a jack! To help with one of these problems, Agency Power’s grab bar is designed with a 17mm and 19mm socket at the end of each side of the handle. When removed from the vehicle, the T shape grab bar provides incredible leverage to help in the tire changing process.
1 - 4 of 4 Posts
