The Rundown:
front:
New balljoints
Now new bearings(reason for video)
rear:
bearings, a-arm bushings
As you can see in the video(I think) There is a lot of play in the bearing/hub area. You hold the axle and the slop is mostly gone, but the slop isn't in the axle itself but appears to be in the area of where the axle meets the bearing/hub etc...
The bearings are in all the way as the clips are in their respectable slots! The only thing I can think of is that the washers and the nut for the axle are worn out???? They are tight with cotter pins in. We even went to the extent of using a 1/2" breaker bar to see if they needed to go tighter and it didn't matter...
Anyone know what the issue is?
front:
New balljoints
rear:
