1 - 20 of 105 Posts
Wanting an easy attachment spot for your tie down hook on your Polaris RZR UTV model? This kit will give you 4 tie down spots on the suspension of your Polaris RZR UTV! Uses all stock hardware and bolts to the bottom of the shocks. Sold as a kit of 4.
Kit has been test fit on Polaris RZR XP 1000, XP Turbo, RS1, and XP Turbo S. May fit other models as well, but have verified fitment on these units.
MSRP $35.00
UTVINC.com: https://www.utvinc.com/utv-inc-polaris-rzr-xp-1000-lap-belt-mounting-kit/.html
Amazon: https://www.amazon.com/UTV-INC-Polaris-Suspension-Down/dp/B07PJVDTGG/ref=sr_1_2?keywords=UTV+INC+RZR+tie&qid=1565366392&s=gateway&sr=8-2
Ebay: https://www.ebay.com/itm/223617913259
Re: UTV INC RZR Tie Down Mount Kit
Is this kit used for tie down points when trailering? Or to compress your shocks for people's who's RZR's are too tall for their toy haulers?
  • Like
Reactions: UTV Inc.
This kit was designed with the intention of being trailed off these mounts. You are pulling from the bottom of the shock as the photos above show, so you will not compress the shock by pulling it down from the bottom.
EDIT:
If you bolted these to the TOP of your shocks and ratcheted down, then it would compress the shock.
Okay. I was trying to picture exactly how I'd tie down to a trailer from these points. Specifically the front, since it looked as if the tie rod might be in the way of a strap.
Also it looks like if you were to mount them in the same place as you have in pics, but with the loop pointing upwards, you could hook from there up to the frame and compress the shocks while still being able to drive into a toy hauler or enclosed trailer. This may be the answer for those who have to let air our of their tires or have to use a smaller set of wheels to get in those lower clearance enclosures.
  • Like
Reactions: UTV Inc.
Damn it! I thought I was done buying accessories.
It.......... never................... ends..............................
  • Like
Reactions: Denver and UTV Inc.
Discussion Starter #7
Very well could work multiple ways. Thinking outside the box, we like it!
I dig it, finding good strap tie downs can be a challenge. might have to pick up a set.
Discussion Starter #15
Wanting an easy attachment spot for your tie down hook on your Polaris RZR UTV model? This kit will give you 4 tie down spots on the suspension of your Polaris RZR UTV! Uses all stock hardware and bolts to the bottom of the shocks. Sold as a kit of 4. Click on the link below for more info.
LINK: https://www.utvinc.com/utv-inc-polaris-rzr-suspenion-tie-down-bracket-kit/
Bookmark
1 - 20 of 105 Posts
