Want the ability to quickly remove a steering wheel on your Polaris UTV (RZR, General, RS1)?! The UTV INC Quick Release Steering Wheel Hub Adapter is the best on the market! Easy to install. No cutting, welding, or any modification needed to your machine for install. Simply bolt the supplied spline drive adapter to the stock steering shaft, affix a 5 or 6 bolt steering wheel of your choosing, and push the steering wheel & hub onto the machine. Easy as that! This hub is designed to keep the UTV INC steering wheel in the stock location, so the wheel will not be closer or further away from you once installed. This hub will fit ALL models of the Polaris RZR, General, RS1, as well as Ranger 900XP, 1000 and Diesel models. If you are unsure if this will fit your unit please feel free to ask prior to purchasing. Includes all hardware needed for installation.
$180.00
LINK: UTV INC POLARIS QUICK DISCONNECT STEERING WHEEL HUB ADAPTER
